dead battery - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 12-29-2012, 05:12 PM
petey7102 petey7102 is offline
Mein Auto: 2002 X5
dead battery
2002 X5, have replaced alternator ($950) and battery and battery is still dead after a couple of mornings. Assume electrical draw someplace. Any ideas?
Old 12-29-2012, 07:37 PM
Zulu95's Avatar
Zulu95 Zulu95 is online now
Mein Auto: 2001 X5 3.0L
Go to xoutpost and search on FSR.
Old 12-29-2012, 07:46 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Which did you replace first...the alternator or the battery? If you replaced the battery first...and the new battery went dead before you figured out to replace the alternator...depending on how discharged the new battery got...it may have been damaged or just need a good long, low amperage recharge for a good 20-24 hours.
Or you could have gotten a bumb new battery...does it have a date sticker on it? Did the vendor put a charge to the battery before they gave it to you? Have you unlocked your OBC so that you can run TEST 9 to see what the battery voltage is? Or dp you have a multimeter that you can use to check what the new battery's voltage is?
Q {BMW CCA Member #191509}
(SOLD)
