E36 (1991 - 1999)
Old 12-28-2012, 10:44 PM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
that other kid
Mein Auto: 92 325i and 98 328i
My new DSII's
Got a set of DSII's for $450. No curbrash, perfect condition. All of them have good Faulken tires with about 1/2 tread. Pretty happy about it.
Anyway, I'm running racelands right now and 12mm spacers to get my style 41's (came on the car) to fit.
Put my DSII's on (The tires are 245's btw) and they stick out past the fender about a half inch.
What should I do
Old 12-28-2012, 10:45 PM
Eight Thirty Eight Thirty is offline
nothing.
Mein Auto: ItAintUrShtYUCare?
get 5mm spacers
stretch tires
roll fenders
get new wheels
pick one.
nothing.
Old 12-28-2012, 10:46 PM
that other kid
Originally Posted by Eight Thirty View Post
get 5mm spacers
I could get new wheel spacers but don't they have the same offset as the style 41's...which rub without the 12mm's?
Also I dig the wide tires. Handling > Low IMO
Rolling fenders right means I gotta buy a fender roller if I'm correct...
and no.
Old 12-28-2012, 10:48 PM
nothing.
the ds2's sounds like a square set.
are they all 245's on the tires?
the style 41's are 7j wide i think
ds2 is 8.5 wide. so the 12mm spacer is making the ds2 et29 which is increasing the distance between the strut and the wheel.
nothing.
Old 12-28-2012, 11:37 PM
that other kid
Yeah they are a square set, 245's all the way around. So run 5mm spacers to have a Et of 34 and maybe roll some fenders?
Old 12-29-2012, 06:03 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
With a stock suspension, you can run DSIIs with 245s all around with no spacers (or fender rolling) whatsoever. If you're on Racelands, the only thing you should need is a small spacer up front (10mm or less) to clear the lower spring perch. Shouldn't need anything out back.
1998 BMW 328is
1966 Pontiac GTO
Old 12-29-2012, 09:38 PM
that other kid
Thank you sir.
