Old 12-24-2012, 03:21 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
E39 99+ rear window regulator options
Hi
Well my rear driver window regulator went, looks like something with cable drive which mangled cable a bit. So it needs a new regulator.
Looking around there seems to be 3 options:
1) OEM part, inc motor ~250
2) dap ~150
3) uro ~100
The suggestion on here is uro is not very good quality and most mention early failure. Haven't found any mention dap.
Does any one have personal experience of dap/uro?
Trying to figure out if it better to pay money for OEM one or try save a bit of money.
Thanks.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 12-24-2012, 08:09 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
OEM has a metal moving piece, but still a crap plastic lower securing point for the glass, while URO is completely plastic.
My PO put a URO on my rear window, and the regulator itself is good, but the motor crapped out , i was a bit hasty on eBay and bought another URO one, but since it's the rear window I wont put too much thought into it... OEM or not, all the regulators suck.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 12-24-2012, 09:31 AM
Samy22 Samy22 is offline
Mein Auto: BMW
Hi Mbel,
look at this page: http://www.idealautoteile.com/categories/BMW/E39/
They offer a lot of different window regulator repair kits for a very fair price!
Old 12-25-2012, 03:42 AM
Thanks, yeah think they all probably suck just case of suckiness v cost. Those parts look like good option but appear to be for the 97 to 99 regulators so won't fit mine.
Also found a dorman one for ~115, this comes to be redesigned updated part. So might well give that a go.
Old 12-25-2012, 04:53 AM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
I used this one http://www.dependable-autoparts.com/...dow-regulator/ Shipping and all it was less than $60.
So far so good and it appeared to be of heavier construction than the OEM that I removed. It didn't come with a motor so I reused the OEM motor. Keeping my fingers crossed. Good luck.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 12-25-2012, 04:57 AM
Oh, I just noticed that it doesn't fit 1999 model, but it appears that they have some on their site that do. Best of luck.
Old 12-25-2012, 11:39 AM
2) dap ~150
3) uro ~100
I just did research for my front window regulator - and I came up with these about a month ago (most 'should' apply to the rears, I would think):
I will search for regulator suppliers ... so ... if you have experience with particular brands and suppliers ... please let me know.
- Supplier prices lookup comparison engine (1) & BMW salvage (junkyard) parts lookup engine (1) & BMWfans search by part number (bmwfans.info parts catalog) & Realoem nominal prices by part number (1) & EACTuning actual prices by part number (1) & BMW of South Atlanta actual prices by part number (1) & Maxmillian BMW dealer prices by part number (1) & the most often recommended parts suppliers (1) & what BMW E39 parts & supplies are best to buy OEM (1) & joining BMWCCA to lower parts costs (1) (2) & what parts to always get OEM (1) which BMW dealers match prices (1) & in situ pictures of common parts of the M54 engine (1)
EDIT: Seems like the following brands are available:
  • OE 51 33 8 252 393 (Kuster is the original brand name on mine) 51338252393
  • A1 Cardone 82-2134A
  • Action Crash 1032-04050415
  • Dorman #: 740-478 or #740478
  • Hollander #: 125-58598L
  • JL Germany (Bavauto seems to sell this)
  • Partslink #: BM1350103
  • Replacement B462922 (The Parts Bin & DriveWire & auto parts warehouse seem to sell this)
  • Üro Parts 51338252393 (BMA, AutoHauzAZ, Amazon, seem to sell this)
  • VDO/Siemens (Amazon seems to sell this)
  • World Source One W0133-1601605
  • ? what others ?
Note: The driver-side front regulator seems to go by two different part numbers: OLD: 51338236859 NEW: 51338252393
Note: Part #51338252393 is for the front left, driver side; while part #51338252394 is for the front right, passenger side.
Note: E39 models built before 9/1997 apparently used a slightly different mounting method than later models do (mine is a 2002).
Note: It's interesting that Turner Motorsports has multiple items of the exact same price & brand as "The Parts Bin" (URL not provided as it is asterisked out when I type it as a single word).
Note: Here is a typical supplier's picture of the OEM brand (Kuster).
  • Notice I flipped all the pictures so as to always show the true orientation (most suppliers show it upside down)
  • Notice the white plastic take-up spool assembly is tie wrapped to the metal motor plate so I presume we need to re-use both the old motor and the five screws which held the old take-up-spool mechanism to the metal motor plate
  • We probably need to re-use the three T25 bolts at top which don't show in this picture
  • The two bottom 10mm bolts seem to come with the window regulator
  • The two window clamps seem to come with the regulator (each clamp has a T25 bolt, rubber "edge protector", T20 bolt, and the plastic window stop)
  • The regulator appears to come with the T20 bolt and clip at the center (which clips the bottom portion of the motor plate to the door)
  • The small rubber stopper on the motor plate seems to come with the regulator (this is a separate part number in realoem diagrams)
Old 12-29-2012, 09:58 PM
cowboyjer cowboyjer is offline
Mein Auto: 2000 528i
I bought a regulator from dependable auto for my 2000 E39 rear door, and it failed in less than a month. They refused to replace it, stating the warranty was only 30 days. Not only is the part junk, they don't stand behind them. I would recomend trying somewhere else.
Old 12-29-2012, 10:08 PM
Dependable auto sells on ebay as a DAP part for 29.39 with a 30 day warranty, and on their website direct for 55.90 with a 45 day warranty. i received the part on 11-15, installed the first or second week of December, and it failed yesterday. The window works feely with no restrictions.
Old 12-29-2012, 10:09 PM
I'm actually having trouble with mine too ... so maybe we need to strike them from the list. Dunno yet as I haven't re-opened the door panel yet.
Old 12-30-2012, 08:35 AM
I went for the dorman one for ~$115. It seems to be decent enough quality, no obvious differences to oem and is made in Taiwan. Fitting it went fine, window is working now but seems a bit louder ( motor straining noise) than before. Will see how it lasts and report back any problems.
Thanks.
Old 12-30-2012, 09:20 AM
Makomagnet Makomagnet is offline
Mein Auto: 2001 525
Just changed mine (01 525). First replacement came from Autozone because it was in stock. Lasted about 1 week till heard the spool starting to slip. Was loud and sounded cheap and cost was $260 (was after market).
2nd replacement came from Turner Motor Sport same price but was OEM BMW.
Spend the $ it's a pain to change.
Old 10-14-2013, 06:32 AM
A duplicate thread was opened today so I paste the OP here for reference ...
Originally Posted by mio_e46 View Post
Hello Guys - It appears my front passenger side window regulator is about to go out - looking to replace it and I found one thru a company called Uro for about 89$ where as I can get the OEM one for 147$ -- wondering if anyone has used the Uro version and whether its worth it to save a few bucks - your input is appreciated.
Old 11-21-2015, 05:10 AM
Wgosma's Avatar
Wgosma Wgosma is offline
Mein Auto: 2000 528i M-sport 5spd
I need to replace a rear door window regulator....anyone care to chime in on what brand to purchase? (looks to me like the URO is a good bet).
Thanks/Bill
Bill / Oceanside, CA
00 528i - 5 spd M-Sport
Old 11-21-2015, 07:37 AM
Dking078's Avatar
Member Supremo
Thanks/Bill
I got URO on both my rears (OEMs up front) and still haven't had any issues. Then again I hardly lower the rear windows, but every time I do it's never had a hiccup.
Old 11-22-2015, 08:36 AM
Stueyo Stueyo is offline
Mein Auto: 528i bmw 2000
trying to find fuse that operates the windshield washer pump
Old 11-22-2015, 01:26 PM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 03 530iA Sport
Thanks/Bill
I bought the Vaico brand regulator yesterday from ECS Tuning for ~$70; Üro was ~$100 and BMW (motor included, which I don't need) was $270. I use my windows a lot actually, so I'll report back if I get any failure/quality differences between the factory regulator and the Vaico.
Nate J.
RIP, Seabiscuit - 03-11-03 530iA Sport, Sapphire Black/Black. T-boned 03-01-2017.
Take 2 - Toledo Blue. 04-25-2002 530iA Sport, Toledo Blue/Sandbeige.
Old 11-22-2015, 02:49 PM
Wgosma's Avatar
Thanks, let us know about Vaico-Xlnt price indeed.
Old 04-19-2016, 01:04 PM
Well, I've had the Vaico right rear window regulator installed and in near-daily use (if only to crack the windows) since December, and the Vaico- unit still functions well. 4.5 months and counting...
Nate J.
Old 09-11-2016, 02:02 PM
Bummer, the Vaico window regulator in my RR window failed completely; the window is now loose in the door. I do use the windows; not a ton, but often enough, and my black over black car in the hot SoCal sun probably didn't help the plastics. I'm probably going to go with a "Üro Premium" brand from ECS Tuning; the motor still works fine (I can hear it).
Nate J.
Old 09-11-2016, 02:45 PM
bmw blue's Avatar
bmw blue bmw blue is offline
Mein Auto: 2000 bmw 528i
I took a chance on a Doorman regulator from
Auto Parts Warehouse 2 summers ago and it
has held up fine. It was for my left rear window.
I don't remember the price and I'm not at home to look in my pile of receipts.
I lubed it up real good with some white
Lithium spray lube and it has held up well.
Cheers.
Old 09-14-2016, 05:36 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
plus dorman carries a lifetime guarantee
99 528i 5sp sport
be alert...the world needs more lerts
Old 09-14-2016, 07:11 PM
bmw blue's Avatar
Confirmed. I called Auto Parts Warehouse and indeed Dorman products have a
lifetime guarantee. The left rear passenger Dorman Window Regulator Without
Motor, Part #749-001 is replaceable if defective.
I paid $118.40 originally. Price has gone up to $142.91 from (A.P.W.) for said part.
That's pretty good insurance for a part that so commonly fails on the E39. I don't
know if any other manufacturer offers that guarantee or not... doubt it.
If you choose the Dorman Window Regulator or not, make sure you lubricate it
well at all points that need it including the spooled up wire.
Thanks Mattmar1 for reminding me as I had forgotten this salient point.
Cheers All.
