Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E60 M5 (2006 - 2010)
Old 05-19-2012, 01:16 PM
donniesd donniesd is offline
Mein Auto: E60
Unknown Flywheel Damage
Looking for some advice from some other pros on how this could of happened.
After getting erros and scanning for codes. I got error
P0339: Crankshaft Position Sensor A Circuit Intermittent
Took it to the dealer and they replaced the sensor under warranty. After they took it for a test drive, got the same error and told me they needed to tear down the tranny.
As you can see from the pics. We dealer and i are at a loss for what happened. They said started and clutch is in tact and so is everything else. Just the flywheel is damaged. It is not missing any teeth. But they are damaged. They state nothing came out when they took it apart. Car has had not work on it in the month i have owned it.
Warranty wont cover it they say it was caused by "outside influenced"
Old 09-29-2012, 06:11 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
That crank sensor fault will set when ever there's clutch slippage, It is not easy for a rock to get inside the bell housing. I will request dealer to review repair history, do a puMA case, and call aftersales rep for a goodwill warranty.
Old 09-30-2012, 07:28 PM
mustaine's Avatar
mustaine mustaine is offline
Mein Auto: 2007 ///M5
Were you feeling any clutch slippage, hesitation, and/or vibration on take off etc? Just curious..
So, I ask myself the question, what today..... what tomorrow?
Old 09-30-2012, 07:30 PM
mustaine's Avatar
Also, You car's year, mileage, and some service history would help ...
Old 12-30-2012, 09:35 AM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
To me it looks like a lrg bolt was either left in the housing or on came out of something.Wedging between the housing and flywheel. Hard to believe nothing was found in side the unit.
