My car sounds like a airplane - Bimmerfest - BMW Forums
Old 12-26-2012, 07:19 AM
Rubio Rubio is offline
528I wagon 99
Send a message via Yahoo to Rubio
Mein Auto: 528I 1999
I wanted to see if anybody had the same problem or can help me out with my problem my car sounds like an airplane when I'm hitting the gas and it feels really heavy
Sent from my LG-MS695 using Bimmer App
Old 12-26-2012, 07:41 AM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
Clutch fan? Are you talking about the wooshing shound on take off?
Old 12-26-2012, 07:53 AM
guysimmons89 guysimmons89 is offline
Mein Auto: 2003 BMW 530i
It could be your driveshaft about to go. I had that problem on my old car. You can still drive but not far before it goes out.
Old 12-26-2012, 08:16 AM
528I wagon 99
it's more like a humming sound
Old 12-26-2012, 08:18 AM
528I wagon 99
not only take off but it sounds louder on takeoff
Old 12-26-2012, 08:21 AM
528I wagon 99
I have a humming noise that sounds like it's coming from the engine and I have a rubbing noise it sounds like it's coming from a tire rubbing against something I checked all 4 tires and nothing
Old 12-26-2012, 08:22 AM
528I wagon 99
Thank u
Old 12-26-2012, 08:28 AM
Strange. The driveshaft is a little louder than just a hum so maybe not that. I'm not sure what to tell you.
Old 12-26-2012, 10:20 AM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
Does the sound only come on when ur AC or Heat is on? Because mine does that same sound but only when those are on.
Sent from my PG86100 using Bimmer App
Old 12-26-2012, 12:28 PM
waehrik waehrik is offline
Mein Auto: e39 530i/5, e28 535i
There are two main causes of a loud airplane sound: the secondary air pump (electric) and the engine-driven-though-clutch fan.
The relay may fuse on the secondary air pump and cause it to stay on all the time. Unplug the relay to see if it turns off for diagnostics. It will burn out in short order if left to run all the time. It's only supposed to be on for a minute after a cold start to inject air into the primary cats to heat them up faster.
The fan clutch on the front of the engine may sieze up, causing the fan to rotate at water pump speeds all the time. This is even worse as the fan was not meant to go that fast and has been known to explode if it is weak or contacts the shroud due to worn engine mounts. This is easy to identify. At a stop, rev the engine in neutral. If it sounds like it's taking off, then it's this fan and you should change the clutch and fan blades immediately. If it's loud while doing this it also can't be the driveshaft as it isn't moving...
Old 12-26-2012, 01:15 PM
528I wagon 99
Thank u so much
Old 12-26-2012, 01:16 PM
528I wagon 99
Even when the AC is off or heat
528I wagon 99
Lol its cool thank u
Old 12-26-2012, 04:30 PM
When you perform the above diagnostics please report back with your findings. Same if you find a solution.
This way other new members such as yourself can find help in this thread as you hopefully are.
Old 12-26-2012, 04:49 PM
528I wagon 99
no problem will do
Old 12-28-2012, 11:58 AM
poormansM5 poormansM5 is offline
WTB M5 rear diff!!
Mein Auto: 2000 540i6 "Heidi"
could also be your cooling system not doing its job. The car might be running hotter than normal. Check to make sure your coolant level is correct. Any noticable leakage?
[Rebuilt M62TU, Shortshifter & ZHP, Spacers, BC Coilovers, Hawk Pads, Stainless Lines, 20% Tint, & Ebay cupholders. Y Res delete, control arms, bushings, and sways coming soon!]
Old 12-30-2012, 06:57 AM
Joelgk Joelgk is offline
Joel
Mein Auto: 2001 530i E39
Wheel Bearings??
Old 12-30-2012, 09:42 AM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
If it were your SAP, it would ONLY last about 90 seconds after a cold start-up. That's
it! If it is possible it is your fan clutch (do search about rolled-up newspaper) your fan blades could come up right through your hood, destroy radiator, and more. At least see if you can easily stop fan blade on a cold start-up in morning with just a small amount of rolled-up newspaper. If you can't stop your fan blade easily right upon cold start-up, your fan clutch is NG. Then you'd be driving with time bomb ticking. Do not race over about 3000 rpm if you find fan blade clutch is shot.
Old 12-30-2012, 10:39 AM
540iman's Avatar
resident, old fart
go to about 3rd page on bimmerforum and read new post called "clutch fan of death" to see what you *might* be up against.
Old 12-30-2012, 04:48 PM
528I wagon 99
Thank u
Old 12-30-2012, 11:03 PM
damisco damisco is offline
Mein Auto: 99 BMW 540i
sounds like your fan clutch is close to due
