E34 (1989 - 1995)
Old 12-30-2012, 11:47 AM
pnz pnz is offline
Mein Auto: 94 540i
never reached the red
94 540i the aux pump fitting broke off due to its age,drove only five miles, car never hit the red zone...any damage?
Old 12-30-2012, 11:58 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Probably not since it didn't go in the red. But only you will know after making the repair and watching for any signs of problems or damage.
Also, no need to start another thread. Your situation was discussed in your previous one.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 12-30-2012, 12:12 PM
pnz pnz is offline
Mein Auto: 94 540i
pnz
thank you for the reply...i am waiting for a new aux pump fo be delivered...bypassed the heater core until then..no white vapor..no water in oil..did the candle test and checked for bubbling in the radiat
or..nothing..dip stick free of moisture..underside of oil cap moisture free..no oil residue in rad. i have read it not a good to run 540i past the halfway mark...????
Old 12-30-2012, 12:48 PM
BMR_LVR's Avatar
Humble E34 lover
It's best not to, however, the V8 is a little more durable and resistant to head gasket failure secondary to overheats than the I6 since the heads are not so long.
I imagine that you did no damage. Just keep a watchful eye out for a while.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 12-30-2012, 07:13 PM
Banned
Mein Auto: car
Well it will not damage the engine to run it at 3/4, which is why red is where it is, and the distance from 1/2 to 3/4 is shorter than the distance from 3/4 to red, however that is not the optimal temperature for ideal combustion in an engine. You are safe, but nevertheless, it never hurts to do all the tests that bmw_lvr has suggested that you do.
When you top up anti freeze, bleed the radiator according to the bentley manual (please search for the download), but prepared to see air pockets coming out and manifesting itself as falling coolant levels in the expansion tank. I had this for 3 weeks after I changed a radiator and bled it twice perfectly. Our systems trap air well and it takes time for that to be fully evacuated to the radiator. So please monitor coolant levels daily until it stabilises, and topup if it falls below the cold mark when the engine is cold.
