Old 12-28-2012, 10:55 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
Aftermarket rotors - Centric
Does anyone here have any experience with the Centric brand brake rotors? Looks like they are out of California.
Old 12-29-2012, 07:29 AM
Oceans10's Avatar
Oceans10 Oceans10 is online now
Mein Auto: BMW 535i + 535XI wagon
I just put Centric Cryo treated rotors on my front. With Hawk HPS pads. Feels oem, except a lot less dust. My rears are now dirtier than my fronts, so this is now my pad of choice!
The Centrics were plain, no slotting or cross drilling as it reduces the stopping surface and chews up pads faster. I got them from Tire Rack. Pads from THmotorsports.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 12-29-2012, 08:08 AM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
IMHO... they are cheap crap rotors. I went through two sets on my front axle, always warped within 1500 miles. I even resurfaced once so they warped three times on me. Finally took car to dealer who said the rotors were poor quality and replaced with OEM... no more warping since. If I was gonna try them again on an e60 I would suggest the slotted version to help with heat build up. I should add that I have used these rotors more successfully on other model BMWs and I do believe the e60/e61 brake design is undersized.
Old 12-29-2012, 08:17 AM
johnniek johnniek is offline
Mein Auto: 2009 528ix sedan
Centric Rotors
I've put them on 3 vehicles so far:
2003 GMC Yukon XL
2001 Toyota Avalon
1994 BMW 525i
Every install I used Akebono pads, and I've had no issues, and I've been very pleased with the performance. I recommend them, especially because of the ecoating that inhibits rust as compared to other brands. Akebono Euro Pads are terrific for good braking and low dust.
Old 12-29-2012, 10:59 AM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
That's odd. I went with the Centric rotors with E-Coating and they've been great. No warping, no rust, and seem to be an excellent value. I'd buy them again in a heartbeat.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 12-29-2012, 04:53 PM
dkotanto dkotanto is offline
Mein Auto: 2003 BMW 530i sport
Warped under light use in my daughter's 2004 X3, after about 6000 miles. Used them (Centric Premium rotors) with StopTech Street Performance pads. Had them bed in properly at install time too..I'm quite disappointed at Centric.
2003 530i Sport - Current
2007 530 xi (wife's car)
2004 X3 3.0i (daughter's car)
2011 E90 M3 ESS VT1-550 (Sold)
2006 530i Sport (Sold)
2004 330i Sport (Sold)
Old 12-30-2012, 09:40 AM
Hogie's Avatar
Thanks for all the replies. Mixed feedback which was very helpful. I did go ahead and order the Centric Rotors from Partgeek.com. I will most likely install next Saturday.
Just an FYI, when BMW did my front brakes for the first time the BMW rotors warped within about a month of installation. They replaced for free. Other than the grade of material used I think a mystery on why some rotors will warp when used under normal driving conditions. For me I think proper break-in for the first 500 miles and proper wheel lug torque are critical.
I'll bookmark this post and report back in a month or so and let you know how they are doing.
Old 12-30-2012, 12:52 PM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
Neither of your rotors 'warped'. See: brake pad deposition. Break-in the pads correctly and you won't have this problem.
Old 12-30-2012, 02:38 PM
Clean the hub surface really good with a light wire brush, this is key to the rotor being fitted flush to the hub and huge factor in avoiding warpage.
Old 12-30-2012, 02:53 PM
z0lt3c's Avatar
Although pad deposits can and did contribute to my problems, to conclude that improper bedding is solely to blame is a stretch. When I had my centric rotors resurfaced they were measurably warped and exhibited clear signs of heat build up. The pads may play a large factor as I was also using Stoptech (centric brand) pad. A trusted indy mechanic performed the install and bedding procedure for me in 2 cases of failure, while I did it all myself the third time. The rear brakes, where the heat build up is much less, are also/still centric/stoptech, have never exhibited a problem for almost 7000 miles now.
Old 12-30-2012, 07:54 PM
Let me guess, the 'trusted indy mechanic' is the jerk off know it all at the Oldwick Garage...
Old 01-08-2013, 01:53 PM
Hogie's Avatar
Update:
Received the new Centric rotors. On a visual inpsection there is a difference in the hub section of the rotor. My BMW rotors have metal circular inserts (best I can describe) about every two inches arounf the rotor hub section. The new Centric rotors are smooth and do not have. Has anyone encountered this or know what the inserts are used for?
Old 01-11-2013, 06:22 AM
Hogie's Avatar
OK I called my local BMW parts department and they were nice enough to pull a rotor from stock and take a look. The area that I mentioned in my last post turn out to be rivets.
While I have seen aftermarket with rivets on the horizontal plane to the rotor surface, these are on the hub, which is vertical plane to the rotor. I thought maybe part of a sensing circuit for rotation etc..
The BMW parts person stated that the BMW stock rotor has a aluminum hub riveted to a cast rotor and that is what they are.
This means the Centric are 100% cast and require no rivets. I am going to do the brakes Sat. so I will give some feedback.
Old 01-30-2013, 10:53 AM
aiwapro aiwapro is offline
Mein Auto: 2013 X5 35d
I purchased the Centric Power Slot rotors, and the Centric Posi Quiet Ceramic pads. It's a disaster, and I don't know which is the culprit. The brakes are so noisy. They have always been noisy in cold weather, and even more so lately when the car has sit in wet weather. For some reason, most of the noise is always in reverse, like backing out of the drive way, or out of a parking space. Recently, normal braking while the car is in a forward motion, does not feel smooth.
The setup was not cheap, so I don't want to replace rotors and pads again, when I just did so last year, and have like 40,000 miles left on them. The rotors look in ok condition. There is some rusting look in the slots, but the surface looks and feels fine. Maybe the rust from the slots is trasferring to the pads. Any ideas. Not sure how I should move forward?
Old 01-30-2013, 08:38 PM
Hogie's Avatar
OK I have been driving on the new front Centric rotors and Bosch Quiet Cast pads. I have about 750 miles on them. They are doing great so far. I can not tell the difference really. I get the same stop feel I did with the BMW stock. I know early with only 750 miles but all is well so far.
Old 01-30-2013, 09:53 PM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
I have those PosiQuiet pads on my car now and, yes, they were super noisy when they were new. Since I've run them in, they've quieted down a good bit, but they still squeel like a scalded pig in reverse if they are wet. I really enjoy the lack of dust, but once my rotors are done, I'm switching to Akebono.
2008 550i Sport-a.k.a. Hot Kraut Garbage
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR Sold
2005 Triumph Daytona 650 (wife) Sold
Old 01-31-2013, 06:45 AM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
Noisy brakes are almost 95% installation. Were the brakes thoroughly greased? Are the caliper slide pins greased or otherwise working properly? Etc.
Then bed-in and whether or not they were installed on used rotors, which sometimes the grooves on the new rotors and the surface on the fresh brake pads create harmonics.
I've used centric rotors several times with outstanding results. In many worlds, they are considered an outstanding OE-style rotor. It is very rare for rotors to warp under normal driving conditions. If they are off-set to the hub, if the wheel lugnuts are way over-torqued, or if the calipers are not evenly applying the brake pad....those things will all warp a rotor quickly....and yet the rotor will often get the blame as crap.
Just to be clear, I've used cheap chinese $25 rotors that don't warp when installed properly, with good hub centricity, working calipers, and torqued lug nuts. Centric is far from a cheap chinese rotor.At the very least, they are an appropriately priced chinese rotor
Old 01-31-2013, 12:11 PM
Great post and mostly true in my case as I didn't replace my rotors since they only had about 5k miles on them. I made sure i greased every point of movement I could which explains the lack of noise going forward. They only squeal if the pads are wet going in reverse (like after washing the car)..once dry they are perfectly quiet.
Others:
Old 02-11-2013, 10:56 PM
Good to know, so it's my pads. I have a lot of wear left on these rotors, and not sure I can take the squealing for that long. These squeal in reverse when wet, and also in reverse when cold. I'm in Michigan, so it's cold, and I always back out of the driveway. This equals a loud loud loud squeal every day of Winter.
So no complaints like this on the Akebono's? I was thinking of going with these or stock pads, and keeping the Centric Power Slot rotors.
For install, I did one wheel myself, and took it to the dealer for the rest, because I could not get the caliper bolts loose. I assume they did it right, and they checked my work, and said it was good also. I did the brakes all the way around on my previous E39, so quite familiar with the process.
Sent from my SGH-T999 using Bimmer App
Old 04-04-2013, 03:22 PM
Hogie's Avatar
Just and update on Rotors and Pads.
The rotors are doing fine. I have several thousand on them now and no issues. They did not have the zinc coat on the hub so they starting to rust a little. For this reason alone I would go with zinc coated in the future.
The Bosch Quiet Cast pads are doing very well. I am also pleased that they are not putting out the black brake dust that the BMW OEMs did.
Old 04-04-2013, 08:50 PM
Damon54 Damon54 is offline
Mein Auto: 545
Have some Centric brand Stop Tech front rotors I have been waiting to install. This thread & the mixed results gives me some pause.
Zeckhausen sells them so does Brake Warehouse which are both highly competent Companies that I do not believe would deal in crappy products. What gives?
125.34071
Old 04-04-2013, 10:49 PM
RIHI RIHI is offline
Mein Auto: BMW
I've used Centric rotors in my installs and not have had or have any issues. They are an OEM manufacturer for other car makes. There is a post in this or another forum (I can't recall), but he installed R1 rotors and Hawk pads and was warped in 1200 miles. The company replaced the rotors with Cryo rotors if the person added another $50.
Old 04-05-2013, 12:19 AM
gcvt's Avatar
gcvt gcvt is offline
Mein Auto: 2008 550i, Sportsmobile
I'll be installing my Centric rotors and Hawk pads on Saturday. I'll report back on how they perform in the future.
2008 550i, Sport Package, Sport Transmission, Active Steering, Navigation, Comfort Access, L7 Audio, Miro 111 wheels 19", full MagnaFlow Exhaust.
Old 04-05-2013, 07:06 AM
core22 core22 is offline
Send a message via AIM to core22
Mein Auto: F10 M5
I had Stoptech drilled/slotted rotors and Stoptech Street Performance pads. Rotors warped in under 2 months. Modbargians worked the warranty for me directly with Centric, who replaced the rotors and pads at no charge, but sent me Stoptech Posiquiet pads instead. Centric advised that since I wasn't tracking the car I should not be using the Street Performance pads. I've had this setup of Stoptech Posiquiet pads and Stoptech drilled/slotted rotors now for about 10,000 miles and, other than squealing at temps under 40f until they warm up, I have no complaints. The squeal is usually just backing out of the driveway. By the time I'm exiting my parking lot at work the squeal is gone. Temps over 40f no squealing at all. OEM performance but the brake pedal feels softer now, which is fine for me as tapping the pedal with the OEM setup would cause the brakes to bite hard - had to be very gentle before.
Big thanks to Frank at Modbargains who stepped in for me and arranged all replacement parts with the manufacturer.
M5 (F10) | Alpine White | Black Merino | Fineline Anthracite
640i GC (F06) | M Sport | Sapphire Black | Amaro Brown Merino | Red Sycamore | M Performance Exhaust
535xi (E60) | M Sport | Platinum Gray | Black Dakota | Walnut | Dinan S2 | BMS DCI | KWv3 | Beyern Mesh
525i (E60) | Sapphire Black | Black Dakota | Walnut
Old 04-05-2013, 08:26 AM
andymax andymax is offline
Mein Auto: 08 535xi
I installed Centric non-cryo rotors about 2months ago with Hawk HPS pads. The feel and stopping power are awesome and I have almost unnoticeable dust. However, I am now concerned about my rotors being warped...I'm going to have to check with a runout gauge and maybe contact Centric. I am aware that other issues can present similar brake pulsing feel, so before I claim anything with Centric I will verify. I am not particularly hard on the brakes...lots of highway miles, with just an occasional sprited backroad jaunt. Has anyone else had depositing issues with HPS pads?
