Old 12-30-2012, 03:45 PM
RyanAustinOlson RyanAustinOlson is offline
Mein Auto: 2012 335i Coupe
Question Technic's HIFI Harness
First off I will start by saying that I am really new to this. I just ordered one of Technic's HIFI harnesses for my 2012 335i Coupe (E92) with HIFI sound.
I am curious to know if this device has any limits. Does it matter the wattage of the sub-woofers and amplifier? Is there any way that I can damage any other parts of my car like the OEM headunit or other parts of the OEM system?
Basically, is there anything important I should know when choosing the sub-woofers and amplifier that I am going to be putting in my car?
I was thinking I would do 2 12" Kicker sub-woofers at 800W peak power and 400W RMS per subwoofer. (Its a loaded enclosure). And then to go with an Infinity Kappa One amplifier at 1600W Peak power and 800W RMS.
Would this setup work?
Old 12-30-2012, 04:14 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Ask on the audio board.
There is much more audio expertize there, also ask Technic he has done a lot of systems.
I have been told you will start to have trouble with the electrical system keeping up at about
2000 watts . Also if you replace the stock amp you need an amp capable of accepting balanced
signals.
Yes you have to be careful because anything electrical can be shorted out.
If you don't have some experience with stereo or cars you should get some local help.
Its not that much more difficult than hooking up a home stereo or entertainment system
with the exception of taking off the panels and routing the wires.
You should no how to use a volt ohm meter and what the readings mean.
You need to study this
http://www.e90post.com/forums/showthread.php?t=641323
Old 12-30-2012, 04:57 PM
signals.
I am not changing the stock amp. Everything OEM that is in the car is staying there. I am only adding the addition of trunk sub-woofers along with an amplifier.
Old 12-30-2012, 06:05 PM
Go to the audio board the experts on bass are there.
Old 09-27-2013, 12:09 PM
revero17 revero17 is offline
Mein Auto: 2009 335i M-Sport BMW
if you are going to add woofers in your car then all you will need is a line output converter from the midbass drivers signal and run it to your monoblock amp. there is no limit to what you put in you car except your vehicles electrical system. at 800rms of power i would recommend you add an extra tiny car audio battery like the kinetic hc600 which can be found for 70 bucks on ebay shipped to your door. if you need any more car audio help please let me know
Old 09-27-2013, 09:10 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
I'm running 1000 W RMS.... one Alpine MRP-M500 and a JL 500/1.
No problems what so ever. You don't need an extra battery. I would try a cap before adding a second battery.
The technic harness has no limits in terms of how much power you can push through your sub. Your aftermarket amp will limit the output of your sub. The technic haness contains a LOC already and all that does is provide the remote signal to turn your aftermarket amp on and to send the audio signal to your aftermarket amp for it to amplify.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 09-15-2015, 05:18 PM
jcrocha jcrocha is offline
Mein Auto: BMW 328i E93 2008 con
Hello, I have a 328i 2008 Convertible with HiFi sound system and I want replace my amp. How can I have or order the technics HiFi harness? Thanks for your help! I wil be en Miami in October and will have a Hotel direction for shipping.
Old 09-15-2015, 07:13 PM
Technic harness
You will need to private message technic himself and pay through his method of choice for the harness. And for the person who stated running 1000rms without any extra tiny battery and wants to consider capacitor, just because you have 1000rms peak power amps does not mean you are pushing that amount. You car's electrical system is designed for your cars stock electronics specifically and electronics are sensitive when it comes to inadequate voltage. So running another battery the size of your foot is not much to ask for especially when a capacitor only aids your car audio system and not your stock electrical system. Anyways, now that my rant is over just pm technic, I bought 2 harnesses from him and he will always be honest and ship your item out.
Old 09-16-2015, 06:03 PM
Dear revero17, how can I send a private message to technics?
Old 09-16-2015, 09:32 PM
Do you know how to do a PM here
You just look up Technic in the email(pm message) portion of the forum
and send a request. Like at the top of the page when you open the forum site,
where it says private messages.
Old 09-17-2015, 08:32 AM
Thanks ctuna, I am new here, but now I know. Thanks again
amplifier, e92, harness, subwoofer, technic
