Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 12-30-2012, 04:56 PM
vasilisbmwm3 vasilisbmwm3 is offline
Mein Auto: 316i e36 compact
Question Convert compact to m3
Hello everybody and Happy New Year !
Greetings from Greece ! :-) I am a bmw lover and i want your help about convert my 316i compact e36 to m3 e36... I just wondering if you can help me out with these by telling me what im gonna need to make it and also any link to check the parts that im gonna need ...
Thanks for your help ! BMW RULES !
Old 01-07-2013, 10:54 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
There's a ton of stuff to do. It's been done multiple times. I can't do all the legwork for you, but if you search around, I'm sure you'll find it. The big differences lie in suspension and engine. There are some minor other parts, but one problem with the compact is the rear suspension is very different than the other types (4 door, coupe, convertible) so most people do what they can from other models (like the Z3 or the E30 M3).
You're looking at a lot of work and money, but it will be an awesome car when you're done.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 01-15-2013, 07:33 AM
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 328i, M3, 325is M-Tech
To do the conversion, you will need a donor car. Preferably one that was wrecked from the side, but front or rear will be fine as well, provided the engine is in good condition and the driveshaft is still straight. You will also need to get the electrical components for ECU and so forth.
It is much better and "cheaper" if you had a wrecked donor car.
bmw. m3, compact, e36
