E36 (1991 - 1999)
Old 04-14-2009, 08:01 AM
agamemnon1970 agamemnon1970 is offline
Mein Auto: 1996 328i
Cool 1996 328i misfire cyl #4 Please help
Well I'm going crazy. My 328i has a check engine light telling me Cyl 4 is misfiring. If I shut the car off and wait 10 min the miss will go away. I've swapped coils with no luck. I've swapped injectors with no luck. Seems when I clear the code the or shut the car off the miss goes away. Am I right thinking that the computer is bad? any help is appreciated. Thanks.
Old 04-14-2009, 06:18 PM
e30e e30e is offline
Search: Top right corner
Mein Auto: e36 m3/4
Obd-II requires you clear the code with scanner. I would inspect the plug and do a compression check.
Old 05-16-2012, 08:09 AM
cliffxr cliffxr is offline
Mein Auto: 98 328i
My '98 328i is doing virtually the same thing but on cyl #6. I've tried swapping coils/injectors also and still no luck. I even replaced the intake manifold gasket...same problem. Next step is to replace all the plugs although I really suspect something more complicated like a bad connection at the DME possibly. The fact that it's intermittent and goes away after turning the car off for awhile make it difficult to troubleshoot.
Cliff
Old 05-16-2012, 09:23 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Changing the plugs should have been the first thing you did. Replace them with NGK BKR6EK plugs, clear your fault code, and report back.
1998 BMW 328is
1966 Pontiac GTO
Old 05-25-2012, 04:27 PM
Mein Auto: 98 328i
Misfire solved
I finally tracked my misfire down to the coil pack harness connector (on the passenger side). Wiggling the connector caused the problem again. When I separated the connector, the outer ring wouldn't twist and just pulled straight up. Once off I still couldn't get the outer ring to twist. I found another harness on eBay and once installed correctly, my misfire went away. I'm guessing the previous owner must have had the connector off at one point and never got it seated correctly. Once again it runs like a champ.
Old 05-30-2012, 03:45 AM
marsbondfire marsbondfire is offline
Mein Auto: e39 (528)
I am having a very similar problem. I R&R spark plugs and #4 coil pack that diagnosed as throwing a misfire. Car always has a very rough idle at cold start (overnight). To my mind the harness you refer to is comprised of 1. a bail and a female connector. Unfortunately the harness you refer to is not shown via www.realoem.com?
http://www.realoem.com/bmw/showphoto.do?id=12131703228
http://www.realoem.com/bmw/showparts...25&hg=12&fg=05
http://www.realoem.com/bmw/showparts...18&hg=12&fg=28
This about covers it. Not sure what might be the issue.
Marcus
Old 05-30-2012, 04:18 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Hi Marcus;
Did you try to just swap the missing cylinder's coil pack with one on another cylinder to see if the issue moves cylinder's?
Ed
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 05-30-2012, 08:09 PM
Ed, I plan to do just that....I've just been busy. I will get to it over the weekend. Thanks for responding.
V/r
Marcus
Old 05-30-2012, 08:17 PM
Mein Auto: 98 328i
Marcus,
Here's a picture of the connector. Couldn't hurt to make sure all the pins are clean and straight and reseat the connector.
http://s1270.photobucket.com/albums/jj602/cliffxr4/
Old 12-30-2012, 05:43 PM
shedwrick dean shedwrick dean is offline
Mein Auto: 96 bmw 328i
can a bad injector cause misfire
Old 12-30-2012, 05:56 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Of course.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
