E34 (1989 - 1995)
Old 12-27-2012, 09:14 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Originally Posted by 525iclassicguy View Post
My mechanic put on the lift and seen it leaking a little bit from heads right under the spark plugs
How was this causing it to run poorly and, how is it related to the oil light coming on?
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 12-28-2012, 08:23 AM
525iclassicguy 525iclassicguy is offline
Mein Auto: 89 525i BMW
I guess cause the gasket was damaged and the hotter the oil got the more oil leaked the more oil leaked the more pressure it loss so i guess that trigger the oil light
Old 12-28-2012, 04:30 PM
Banned
Mein Auto: car
The problem was a piece of the head gasket was bad so until I get the head gasket replace I used some of that liquid head gasket seal and everything works fine now til I get the head job done
Which liquid gasket seal did you use and how many bottles did you require ? Did you have to flush your radiator before and after its use ?
Old 12-29-2012, 11:07 AM
I used the one that comes in the lime green bottle and I only use 1 bottle. I never flush the radiator at all
Old 12-30-2012, 07:05 PM
Banned
Mein Auto: car
Hi 525iclassicguy,
Is this the bottle that you used ?
http://www.steelseal.com/
If it isn't, could you google for the product and post it up here ? Thanks.
