E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#26
I completely agree with you. Its a long shot but if I can cut back on the cost, why not? In all reality its not very hard to recognize that the fan is what caused all of the damage to the car. Literally just got a call while typing this. Turns out that that the fan took out the expansion tank as well (Which I've already replaced this year). Looking at about $850 for this one. I've contacted my original repair shop and they are in contact with the manufacturer and are actually being pretty helpful about the whole thing. Just for fun I attached some pictures from this morning. WARNING: Pictures are of explicit nature.
Last edited by christopherr117; 11-15-2012 at 07:55 AM. Reason: Adonde es mi picturas?? |
#28
I just had my fan clutch replaced to prevent my fan from exploding... as it was locking up fully and causing fan to spin at high speed always under load.
#29
I put almost 140k on my old car that had a nissens radiator with no problems. I would say that it is one of the better aftermarket radiators.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
#30
hey am new here and am looking to see if anyone can give me a help i drop my 550i and am having rubbing issues on the front am running a 245-35-19
#31
Alright so heres a quick update. Total repair cost came out to $844.25. Thats parts, labor, and a free car wash (Hooray??). Silver lining time. The shop that I use at home wants to see the damaged parts and pursue what they can in the way of warranties. Hopefully this will yield some positive results. There have been about 10 different mechanics that have looked at the car and simply cannot figure out what cause the "sudden self destruction" of my fan. The only negative was that I was told I'd have the car by 5:30 today and its now approaching 7 and I haven't even had a call to tell me that it isn't ready yet. Despite being set back a day in my trip home, I would much rather have the car in the best working order.
#32
(sigh) This is Classic Fan Clutch Failure. It's not the fault of a shop that did some work, your fan clutch failed. The fan clutch's job is to disengage at speed so the fan does not turn at the same rate and speed at the engine. The clutch did not disengage and the plastic fan was turning too quickly, and the fan blades came off and the damage you now see is the result. That being said, the only way to test a fan clutch is to take a cold engine, start it up, and see if you can stop the fan blades with the tip of a rolled up news paper. If it stops, the fan clutch is good, if the fan chews up the newspaper, it's bad. It's one of those parts you change out over time as preventative maintenance.
Guys - this is a repair easily done in the driveway with basic hand tools. I'm not trying to be a jerk here, but some basic attention to BMW preventive maintenance and a little willingness to get your hands dirty will save you THOUSANDS of dollars. |
#33
I'm from South Carolina, but live in the dorms of college in Rhode Island. I literally have no access to any tools or any equipment whatsoever. Nor do I have the time to purchase parts and wait for them to arrive as I work two jobs and need to travel for Thanksgiving. I dont really want to hear anything about preventative maintenance, because (if you read) all the damaged parts have already been replaced within the last 5 months. I appreciate your suggestion about checking the fan clutch, however, before insinuating that I'm lazy I'd appreciate it more if you understood my circumstances.
#34
There is a CHEAP $15 (made by MTC) replacement fan for the auto transmission model E46, it is sold as an aftermarket replacement, but it is slightly different in size. It will start tapping its edges on the uppermost part of metal nearest the fan. This will cause your new (CHEAP) fan to break apart soon after install. I bought and installed one and after reading about its problems, I carefully looked at mine for clearance issues. It looks perfect, but after a few miles you will start to see where it is actually hitting as it turns. Just look at the blade edges for proof. Maybe your repair shop used this cheap fan for your replacement as well. As for your radiator, I also had the same thing happen, But was upset because I just replaced the radiator too. So I took mine to a local auto repair shop and had them weld the wholes from the broken fan blade. The cost was $50.
If your fan clutch is still good, you could sell it and buy an electric fan used in the manual transmission E46. That would solve the exploding fan blade issues we Auto trans guys have.
I've seen blades exit the hood on an E39 when the fan explodes.
Apparently I forgot to give everyone the final results. The cause WAS a faulty fan clutch. The distributor for the shop that I used said the fan clutch was up to spec when it wasn't. The clutch allowed for the fan to wobble and the engine compartment is tight enough to where the fan blades would knock and break off after hitting other parts of the engine, and then causing the damage. Total cost for the repair was just over $1,000.
On the positive side, the shop that I use in Columbia is extremely customer friendly. They COMPLETELY reimbursed me for the cost of the repair. All in all it was an unnecessarily painful process that I was lucky enough to have covered by a loyal shop. Thanks for the input and help guys! |
#38
Thanks for that update.
I'll cross reference it to this set of references: - What could cause a BMW fan blade to explode or disintegrate (1) (2) (3) (4) (5) And, the pictures are nice for this pictorial thread: - Pictorial look at typical cooling system failure modes (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
