Fxx or F06/12/13 - couple questions please... - Page 3 - Bimmerfest - BMW Forums
Old 12-17-2012, 08:46 AM
djsaad1 djsaad1 is offline
Mein Auto: range rover
I should be receiving my 650 gran coupe with DAP towards the end of this week or early next week, let me know if you guys need to me search for anything to help you get SLI on HUD on the 640.
Old 12-23-2012, 09:32 AM
How did you guys change the werte value for the DVD in motion? Every time I hit edit and put in FF it reverts back to 00
Old 12-23-2012, 09:39 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
1) Change only the Werte Value, not the Drop Down selection.
2) Right Click on the Werte Value, Select Edit, then in the lower window change the value to FF, and then in the upper right hand corner of that lower window, hit the save icon. It looks like a little door or something.
Old 12-23-2012, 09:59 AM
Thanks! The team viewer tab just happened to be on the little door icon.
Old 12-23-2012, 10:10 AM
Team Viewer? Are you doing remote coding?
Old 12-23-2012, 10:30 AM
Its just easier through the desktop. So the laptop is in the car and I am remoting into the laptop from inside the house.
Old 12-23-2012, 10:31 AM
Makes watching football easier too.
Old 12-30-2012, 02:51 PM
What phones are you guys using? Trying to get ringtone to ring through the car speaker but it isn't working by just turning inband ringing to active. I am using a nexus 4 right now.
Old 12-30-2012, 03:03 PM
You Coded INBAND_RINGING in CMB_Media?
Old 12-30-2012, 03:27 PM
Yeah and it still isn't doing it. In CMB_Media I changed the ringtone from 2 to 3 and that worked. I am also able to stream bluetooth music from the phone when I am in external media on the idrive, so it's a little odd it won't pick up the ring tone when I get a call.
Old 12-30-2012, 03:29 PM
I coded mine a while back to test, and mine did not work either, so I am not sure why it seems to work for some and not others.
I will have to test it again.
Old 12-30-2012, 03:49 PM
It seems to be an android issue, a lot of people are having this problem when connecting to different devices.
Old 12-30-2012, 05:13 PM
Yes, and in my case I am on a corporate Blackberry.
Old 12-30-2012, 10:24 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
INBAND_RINGING works with my iPhone.
Old 12-31-2012, 11:11 PM
I set HUD_VZA and HUD_TLC to active and noticed that the two yellow lane departure lines now show up on the HUD. Haven't got a chance to drive the car yet so I am not sure if it added anything else.
Old 01-01-2013, 11:35 AM
When you guys put the car in park does it automatically put the parking brake on? Or did I accidentally accidentally code that?
Old 01-01-2013, 12:02 PM
Mine doesn't...and thank God for that.
Old 01-01-2013, 12:05 PM
JEG23 JEG23 is offline
Mein Auto: 550i
Do you remember the code change that resulted in the automatic parking brake on?
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 01-01-2013, 12:37 PM
JEG23
I will figure it out when I get home. I was messing with CAS before I left. I was trying to see if I could set auto hold to always on at start.
Old 01-02-2013, 09:29 AM
I have been messing with it more today and it seems like it only engages the parking break if I put the car in park and turn it off when Auto Hold is on. It doesn't engage the parking break if I put it in park turn it off and auto hold is off.
I only started using auto hold yesterday so I am not sure if that is normal or not. If this is normal, then coding auto hold to always on will be harder since you will need the car to always start with the parking break engaged.
Old 04-13-2017, 03:32 PM
ramez75 ramez75 is offline
Mein Auto: 2015 640i xDrive GC
Hi,
So I have seen this in other cars and was wondering if it is something can be done with coding.
So if you low on gas and get the notification then on the Nav get some sort of option if I need to set the navigation to gas stations in the area...
Is that something can be done with coding
Old 04-13-2017, 04:38 PM
Almaretto's Avatar
Almaretto Almaretto is online now
Moderator
Mein Auto: Coded 2016 F10/ F15 Sport
Originally Posted by ramez75 View Post
Hi,
Yes, coding.
  • HU_NBT/HU_CIC: NAVI_FUELSTOP_PROPOSAL = activ
Old 04-15-2017, 10:55 AM
Originally Posted by Almaretto View Post
Yes, coding.
I already have that set to aktiv....but I don't get any message when I am low on gas. Is there something else I need to code or do I have to have a destination set on the navigation for it to work.....
Old 04-15-2017, 04:29 PM
Almaretto's Avatar
Moderator
Destination should be set. You can also decide which POI's are always displayed on map.
