Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 05-23-2012, 12:18 PM
nutrunner nutrunner is offline
nutrunner
Send a message via MSN to nutrunner Send a message via Skype™ to nutrunner
Mein Auto: 2001 e38728isport
alarm not working on my e38
hi all it looks like my alarm is turned off just the lights flashing when locked and i put my arm through thee window how to i turn it back on again ,
[IMG][/IMG]
Old 05-24-2012, 02:30 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
It takes 30 seconds for the interior motions sensor to arm after locking the car with the key. So if you locked the car and stuck your arm thru the window right a way...you didn't give it time to set.
You can also check to see if your alarm siren is still working by activating the PANIC feature.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-21-2012, 08:27 PM
RJK740iL RJK740iL is offline
Send a message via AIM to RJK740iL
Mein Auto: 2001 740iL
alarm / gas cap / key memory options
Have recently acquired a 2001 740iL, and have been learning about it slowly. What I have determined so far is that the Gas Cap Actuator is not working properly. It's not locking the gas cap. That being said, is it possible that as a result of it not working
that the alarm system does not get activated when I close the car automatically via the wireless key (center button). Can you confirm this ?
The DWA flashes about 20 times, 5~10 seconds, then continues with a regular steady flash. BTW, the Panic Button does work.
The other options according to what I've read so far is that possibly that the Interior Movement Detector has been Deactivated, but maybe more importantly, several of these options were never programmed into the key, and as a result are not typically working
as I expected them to work.
I'm going to get the key activated with the options I'd prefer in 2 weeks, and see if that makes a difference in these options working or then determining that there are physical defects to be looked into further.
Current
2001 E38 740iL Orientblue / Beige
Prevous
1995 E38 740i Silver/Grey
Old 12-23-2012, 06:12 PM
QSilver7's Avatar
If your fuel filler door
(SOLD)
Old 12-23-2012, 07:18 PM
gas cap actuator - motion sensor
checked the fuse in the trunk #58 / 5v, was OK, changed it anyway, no difference, tks
Current
Prevous
Old 12-24-2012, 06:14 PM
QSilver7's Avatar
Try pulling the electrical connector to the fuel filler door actuator (see pic below).
The red LED flash sequence you describe indicates that one or more of the monitors is NOT closing...and you state that the fuel filler door isn't locking. That situation will prevent the "keyless" feature of central locking to not operate...thus forcing you to insert the key manually into the door lock cylinder. In the meantime remove the fuel filler door from the mix (unplug it)...then try using the remote to lock the car, the system can't "monitor" what it doesn't see. If it still doesn't lock...then try reinitializing ALL of your remote keys during the same session...follow the instruction to the "T"...and only insert the FIRST key into the ignition...if you have a 2nd key...start programming it 30 seconds after the first on STEP 3:
This is the fuel filler door actuator below...it is unscrewed and turned around so you can see it...when mounted, the black plate that it's mounted to is all you see when you pull back the insulation above the battery...so that means the electrical connector you see on the lower left...will actually be on the lower right when it is mounted:
(SOLD)
Old 12-24-2012, 06:35 PM
will be removing the gas cap actuator from my 95 E38
( works ok there) and then install it into my 01 E38. I'm just hoping that it is the actuator and not the cable, or anything else. My real concern is that the alarm is not being activated, as a result of the actuator not working. I've have sorta confirmed, that no mater how hard I push on the door, or leave the window open and stick my hand inside, ...no alarm. Keys will be re-initialized next week via BMW friend who can do it as if it were just being purchased new. Previous owner may not have taken some options I would prefer. Will also try and remove the 5v fuse for central locking in the rear to see if that takes the actuator out of the mix. Can the cable itself be removed from the actuator, that's actually my plan of attack. Hopefully that will resolve both problems. Tks very much for your advice
Current
Prevous
Old 01-01-2013, 11:50 AM
Smile gas cap actuator fixed, alarm OK now
removed the actuator from the 95 740i, easier than I thought the process would be, had to cut the emergency "open the gas cap door cable", then proceeded to remove the actuator from the 2001 740iL, and install the '95 version. I had some info from other repairs, that helped me with getting the cable into the hole ( remove rubber/plastic cover that holds the pin inside the gas cap area, by turning it to the right, it popped right out.) It's actually a 3-4" tube. I then inserted a thin wire into the now open hole and managed to get it to meet the actuator cable I then attached a piece of electrical tape to the end of the actuator and the wire. I then gently pulled the actuator cable forward, and was able to fish it through the hole. I reattached the the plastic/rubber cover by turning to the left. It held the actuator in place now, and all was done. I open and closed the car doors and the actuator worked. The red flasher on the dash did not go through the old sequence of flashing for 5/10 seconds but rather, went to a steady flash. I then pushed on the door and the alarm went off. A real loud and happy noise. Want to thank you for your advise, and confirmations of my problems. Only a few more minor projects left till it's all sorta perfect.
Current
Prevous
Old 01-03-2013, 08:12 PM
BMWFatherFigure's Avatar
Old School
Lube up cables and actuators with WD40. prevents future probs. I swear by the stuff.
Current:
Previous:
Old 01-03-2013, 08:47 PM
Lube is a good idea - tested old actuator....
I was able to press down on the plastic part and it skwished down as expected, so I reconnected it tot he old 95 740i, and went thru the lock-unlock procedure to see if the actuator moved at all... it didn't. I'm therefore assuming it was not the cabler per se, but rather the electronics part of the actuator that went bad. In any case, WD40 tomm is a good idea.
Current
Prevous
