Help!!! Transmission Malfunction? - Bimmerfest - BMW Forums
Old 01-01-2013, 03:09 PM
boxing119 boxing119 is offline
Mein Auto: 2007 335i coupe
Alright guys so I bought this care about a week ago from texas and drove it home to colroado the car ran great the whole way... now that i am home it has been problem after problem.. So two days ago i must have left a light on in my car. when i went out in the mornng the battery was dead, I called my roadside to have them come give me a jump, As soon as he did that Two lights popped up
1st light - Transmission Malfunction
2nd light - Steering Wheel lock malfunction
The car is a 2007 335i coupe with 43k
Please Help!!!
Old 01-01-2013, 04:02 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by boxing119 View Post
Please Help!!!
Battery tested?
Look around, recent posts on the subject.
Also, you may have nailed why it was for sale.
Old 01-01-2013, 04:39 PM
No this just happened and the dealership hasn't been open since, the thing is none of these lights were on until the jump start
Old 01-01-2013, 06:38 PM
Joe in Dublin Joe in Dublin is offline
Mein Auto: 335ic
jump start may have been done wrong. should have charged battery. maybe charge battery, disconnect for a few then re hook up.
Old 01-01-2013, 06:39 PM
fun2drive's Avatar
BMWCCA 149159
More than likely your battery is shot. You don't need to use a BMW battery and can use a good auto parts battery. Do some searching here and you can't miss at least 5 battery posts in the next 3 pages of threads. Once you get the battery replaced you need to have it registered as BMW uses an Intelligent Battery System (IBS) which needs to know the battery has been replaced to use the correct charging algorithm. More than likely your lights will go out after two cycles unless your jump starting crossed the plus and minus but if they did you would see a lot more issues.
What you are seeing is pretty normal for a BMW that is 6 years old...
Old 01-01-2013, 08:12 PM
How much would all that typically cost?
Old 01-01-2013, 08:36 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
Get a BMW one its warrantied for 2 years so even if you don't get it registered and it borks it will be replaced
BMW is $180-220
If you like customer service. Don't look beyond a BMW.
Old 01-01-2013, 08:44 PM
Thanks for your guys help!
