Old 12-31-2012, 09:30 AM
jeme jeme is offline
Mein Auto: 2011 VW Touareg TDI
I did mine for free, downloaded maps and it did not ask me for a code. Changes? Very hard for me to tell as the car is brand new. I like the way BMW does their upgrades compared to other manufacturers.
Old 12-31-2012, 12:13 PM
ard ard is offline
Resident Curmudgeon
What was you model year AND production date?
My 2012, built in oct 2011, came with 2011 map data. I did not need the FSC code, as BMW preloaded that CODE when the built it, even though the map data was not yet released....
Tgb1974...
Good info. Probably don't need to demonstrate the error- just make sure the document it as your complaint, on the work order in writing...then mention the sib to the SA ....they don't need to put the sib in writing, but make sure he passes it on. Should be no skin off their nose if the sib tells them 'if they complain of X, then do Y"
A
Old 12-31-2012, 12:22 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
Mine was October 2012 and it was able to update to 2013 map without a code.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 01-01-2013, 08:16 AM
Mine is 2012 x5d with a September 2012 build date.
Old 01-01-2013, 08:29 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
Not for everyone!
Since my '13 535xDrive is a July '12 production date I thought I'd check. This was the result at http://store.bmwgpsmaps.com/dataSele...&nocookie=true
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 01-01-2013, 09:11 AM
ard ard is offline
Resident Curmudgeon
why would you spend $245 for this, when you can get it for ~$100???
Old 01-01-2013, 09:53 AM
tgb1974 tgb1974 is offline
Mein Auto: 2012 X5 35d
Tgb1974...
A
Ard, can you post a copy of SIB 65 22 12? Thanks!
Old 01-01-2013, 03:56 PM
ard ard is offline
Resident Curmudgeon
Hey, wait a minute...YOU'RE the one that brought it up!
I dont have it.
A
Old 01-03-2013, 05:38 PM
X5E70lover X5E70lover is offline
Mein Auto: 2016 X5 M Sport 50i
I'm having trouble upgrading mine using 32gb stick. I inserted the USB stick to the center console input while the engine was running & nothing happened. I waited for at least 15 min just to make sure but no response at all. all files were saved on root file using FAT32. am I doing it different?
2016 F15 X5 50i l M SPORT l CARBON BLACK l PREMIUM PACKAGE ENHANCED l VENTILATED SEATS l DRIVING ASSISTANT l HK SOUND SYSTEM
Old 01-03-2013, 05:48 PM
You insert the usb to the glove compartment usb. The center console will not work. Then it will detect the new map when you power up. After flashing, I had to put in new address and drive to it to get rid of a stupid unknown address warning.
Sent from my LG-P999 using Bimmer App
Old 01-03-2013, 07:37 PM
thanks henrycyao it works! but ill have to buy the fcs code.
Old 01-03-2013, 08:59 PM
x5x5 x5x5 is offline
Mein Auto: X5
Just a question for you all. I find the Navigation system almost worrthless and a pain to use while on the road. My phone offers better Nav software, is more accurate, and tells me turn by turn directions BEFORE I get to the turn. It just works better and is more reliable and accurate.
I've always said that Cell phones offer robust functionality that doesn't need to be upgraded like a car and frankly, just woks better overall. I guess I still don't understand why drivers even use in car NAV technology? I wish they merely provided the ability to tether my iPhone screen to the onboard screen. That's all I want and need as it relates to NAV, the phone, email, text, etc.
Old 01-04-2013, 07:24 AM
smyles smyles is offline
Mein Auto: X5
Originally Posted by x5x5 View Post
.. I guess I still don't understand why drivers even use in car NAV technology? I wish they merely provided the ability to tether my iPhone screen to the onboard screen. That's all I want and need as it relates to NAV, the phone, email, text, etc.
Us drivers use it because car manufacturers want to make $$ and resist any cheap technology that will jeopardize their revenues as much as possible.
On a side note, unless you have maps pre-loaded on our phone, good luck relying on just a phone for some ski trip in the mountains.
Old 01-04-2013, 12:54 PM
ChuckGr ChuckGr is offline
Mein Auto: X5 35D
I hardly use the navigation system to input destinations while on the road. I input my destinations on Google Maps while at home and send them to my X5. This works great.
Chuck
Old 01-04-2013, 04:34 PM
Chuck
+1
Old 01-04-2013, 04:47 PM
gresch's Avatar
gresch gresch is offline
Don't be a hammer
Chuck
same here.
And why do people get a car with build in nav? because it's integrated, the screen is bigger than on my phone, and the gps location is more accurate.
Old 01-04-2013, 11:17 PM
Mein Auto: X5 35D
Also if I used a non integrated GPS the directions would not be viewable on my heads up display. I use that always.
Chuck
Old 01-05-2013, 04:11 AM
Mein Auto: X5
Chuck
Not sure I follow your workflow? "send them to your X5?"
Old 01-05-2013, 05:49 AM
gresch's Avatar
Don't be a hammer
using google maps, you can search for a destnation, then click on "more" and send the address to your car. It will show up as a message and you can then just select it as a destination instead of having to enter it in "Manually"
Old 01-05-2013, 12:22 PM
Mein Auto: X5
Thanks for this tip.
Here's what I discovered.
  1. When using a PC/Laptop, etc to access Google Maps online, I see this option. You select your vehicle and enter your BMW Assist email and it sends a message to your vehicle. So far so good.
  2. When attempting this on my iPhone - either via browser or via app, there's no visible option to send to vehicle. You can share via email, but there's no ability to select a vehicle and enter your BMW assist ID?. AmI missing something?
  3. It seems that if you buy the BMW package for $199/yr, you can get Google maps displaying within your Vehicle, thus bypassing the OEM equipped, in car Navigation screen. Sounds like what I want, but is the user experience much improved?
Thanks gain for the tips..I never would have known about this. I wonder what else I'm missing. My wife primarily drives the car so maybe that's why.
Old 01-05-2013, 12:28 PM
Mein Auto: X5
same here.
I've been a long time user of Verizon Navigator on my phone. Has worked amazing anywhere I travel. Love it!...It tells me turn by turn before getting to there and has been amazingly accurate.
When I get into a rental car at the airport, it's what I use to get to and from hotel, meetings, etc. Plus I can save these destinations on my phone. The maps are far more updated than what you can get in a vehicle, and in my experience, my phone navigation is BETTER than the BMW navigation system that put me on a dead end street recently. The same location on my phone got me to the correct place.
Moreover, entering an address on my phone is a very simple and effective process compared to the car navigation system.
Old 01-05-2013, 01:47 PM
gresch's Avatar
Don't be a hammer
X5X5 - When travelling i use navigaiton on my VZW phone as well, no argument there.
Old 01-05-2013, 03:03 PM
ccieurzo ccieurzo is offline
Mein Auto: 2013 328i M Sport
You need to download the My BMW Remote app, then use the google local search option under the "control" button. Don't waste your money on the BMW package. All you get is local search through google. I am pretty sure you don't get the maps or street view unless you have the newest version of iDrive in the 7 series.
Chris
2013 328i MSport
2012 X5 50i (returned due to PCS move)
2003 K1200RS
2008 M5 (traded for X5)
2004 330ix (former winter beater)
2003 M5 (traded with 103k, still working fine)
Old 01-06-2013, 06:24 PM
PittX52011 PittX52011 is offline
Mein Auto: 2011 X5, 2013 550 xi
You can get the new maps for $50 if you have a 32gb USB. This is with FSC code. I did the same. Easy to download. You can find information on F10 forum. Look for 2013 nav update thread. Ask Shawn.
Old 01-14-2013, 07:19 AM
Mein Auto: X5
Finally updated my maps. For DC metro area folks, seems like the Springfield mixing bowl is up to date, but no ICC in MD. I'd say the update is barely worth $50 (thanks for the above referral).
One interesting observation, the update went fine, but now in Options -> Navi version there's nothing, just blank screen. I wonder if my CIC (built 12/09) firmware better be updated.
