Old 12-28-2012, 01:00 AM
sptt144's Avatar
sptt144 sptt144 is online now
Mein Auto: 2009 335i
335i Wind Noise
What is the speed where your 335i starts whistling by your left ear with the windows up? I'm not used to a car cruising at 85 as quietly as this, but when I get to 90 and above it starts whistling. Just want to know if that is typical as these cars are meant to drive at high speeds in Europe and I know my Mercedes was sound proof at 120.
Old 12-28-2012, 02:18 AM
Db750's Avatar
Db750 Db750 is online now
David
Mein Auto: M3 - M6 - 911
Please post your E9x model. My E92 has wind noise coming through the driver window at 80 mph; at 120 it is unbearable . Will send my SA a scathing email and report back.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 12-28-2012, 03:24 AM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
The wind noise gets loud around 135mph on my E91, I do have factory roof rails. It wind sound seems like it is coming from the right rear window, sounds like it is down a little. I didn't notice the sound until I put go flat tires on, the run-flats were so loud at that speed!
Old 12-28-2012, 07:22 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well, my 335i has wind noise at all speeds, but no whistle. I prefer top down motoring.
However, I noticed a screaming noise as the needle passed 130. Turns out, it was my wife hysterically demanding I slow down.
Old 12-28-2012, 07:51 AM
Speedwagon's Avatar
Yep, I know that sound, my wife makes that same sound when we get up to 150mph and we start passing trucks that are only going 50mph!
Old 01-01-2013, 01:41 AM
sptt144's Avatar
I have the E92. I noticed that it must have been a crosswind as I retested it on a different direction E-W vs. N-S. I don't get the high velocity wind noise until about 110-120 but going the other way through the canyon, it was noticable on lower speeds on the driver's side. It is probably normal.
Old 01-01-2013, 06:54 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Yup. On ED, I was looking forward to hitting the engine speed limiter on the autobahn. Turns out the passenger seat speed limiter went off at 120.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 01-01-2013, 06:50 PM
pointandgo's Avatar
pointandgo pointandgo is offline
Mein Auto: '13 F10 535i (loaner)
A belated +1 The dog didn't complain?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 01-01-2013, 07:08 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Mine exhibits a mild whistle from the side mirror from roughly 40-60mph. Below that, nothing; above that, either the resonance is obliterated by increased flow or it's just lost in the background. I notice very little wind noise at freeway speeds--tire noise tends to dominate until triple-digit speeds. Above about 120mph (going from memory from ED; sadly I can't do that here...) the wind noise becomes a formidable roar--not enough to preclude conversation in normal tones, but enough to make the base of your brain say, "OK, we're going plenty fast now...."
Whistling by your left ear at high speed does not sound normal. You might want to have the window glass and seals checked/adjusted, to ensure the glass is fully seated in the seal when closed.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-01-2013, 09:38 PM
jertronic jertronic is offline
jertronic
Mein Auto: 2008 328 xi sedan
The wind noise at and around the drivers side window has been consistently acceptable. I have been impressed quality and durability of the door frame and truck compartment seals. Recently, the seals received an application of gummi pfledge for the first time. Hopefully this will help with prevention of drying / deforming.
Where would one seek repair on the rubber seal network if and when the material fails with age?
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio
