Old 05-09-2011, 10:32 AM
cannottle cannottle is offline
Mein Auto: 325i 06
Adaptive Headlight Failure
I just got this 325i and its a 2006. I have been driving it for a week and out of nowhere a warning comes up on the adaptive headlights. They aren't turning anymore, well at least I think the drivers side isn't. The car has never been in a crash or anything. Does anyone have an idea what could have caused this or how I can fix it with out spending a ton of money? I have searched the site quiet a bit, but up to this point i have not been able to find one that addresses this specifically. So, also if anyone knows of a thread that addresses this pretty well please let me know! Thank in advance!
Old 05-09-2011, 04:16 PM
fazy69 fazy69 is offline
Mein Auto: nothing
Hi I keep having this problem on my 335xi I took it to the dealer three times. They told me that when the car goes over some rough pot holes it knocks the light off the track and needs to be reput on the track to move. Not sure how you can go about it your self and mine is under warranty so cant even give you a price but it seems like its a simple fix when you know what your doing in the shop.
Old 05-09-2011, 04:49 PM
ChrisUNC79's Avatar
ChrisUNC79 ChrisUNC79 is offline
Mein Auto: 335i Coupe
Hopefully it's stuck in the forward-facing position.
PCD 12/21/2010: 2011 335i Coupe 6MT | Black Sapphire Metallic | Saddle Brown Dakota | Premium Pkg | M Sport Pkg | Harman Kardon | Navigation | iPod/USB | Sirius | Smartphone Integration | Heated Seats | Comfort Access
Old 05-09-2011, 06:57 PM
watever watever is offline
Mein Auto: '14 435i
I hit a GIANT pothole and the adaptive warning came on immediately. My car was at the dealers for almost 2 weeks until they finally got it all figured out. Attached is a dialog of what they did. My sincere hope is your problem is not as involved.
ID:	277798   Click image for larger version
Current ride: 2014 435i M-Sport Estoril Blue, Beige, CW, DA, DA+, DHP, LP, PP, TP, MS Brakes, PS, HK. PCD 5/20/14
Most recent: 2007 335i Coupe, Sparkling Graphite, Step, Paddles, Sport Pkg, Nav, PDC, Rear Shade, USB/IPOD adapter ED 4/13/07
Retired: 2003 325i Coupe 5MT, 1993 Mazda MX6 5 Spd, 1980 Datsun 200 SX 5 Spd, 1977 TR7 4 Spd, 1972 Corolla 4 Spd, 1967 Camaro SS 350 4 Spd.
Old 05-12-2011, 05:42 PM
drmwvr's Avatar
drmwvr drmwvr is offline
Stick Drive
Mein Auto: 330i, 911E, UZJ100
Yikes, that dialog is scary......
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold
Old 05-14-2011, 10:22 AM
Mein Auto: 325i 06
luckily the headlights are stuck in the forward facing position. when i bought the car the headlights were set really low so I went and adjusted them to be higher the other day and after i got back in to drive the warning light did not come on, but since it was daytime i could not see if the adaptive headlights were actually working. Then yesterday i hit another pothole and the light came back on. I am taking it to be "diagnosed" monday... we will see what the good dealer has to say.
Old 05-14-2011, 11:28 AM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
(Deleted - didn't realize you got the actual warning message).
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 05-16-2011, 03:28 PM
Mein Auto: 325i 06
So I just got back from the shop and they said that it is a fault in one of the motors on the drivers side headlamp. Apparently you cannot just replace the motor and you instead have to replace the entire headlamp assembly. So that runs about 1k or more so i told them no, and i would just drive with "normal" headlights until i can afford that. Should have bought the extended warranty, and thats now on things to do this week...
Old 01-01-2013, 04:58 PM
rmetchick rmetchick is offline
Mein Auto: 335
I had both of my Adaptive Headlight controls go out within two months of each other. The car is out of warranty but only has 60K on it. The dealer wants $4K to replace the modules, since individual parts are not available. No accidents, no potholes, and no incidents that I can recall. A real bummer! BMW NA wants no part of it and the lights are so bad that I can't drive the car at night. I'm told that this problem is endemic to the 3 series but is not supposed to be as bad with the X5s. BMW apparently saves money by integrating the headlights and controls into a single module but the consumer gets stuck with the tab. It is a safety issue and I can't get BMW to own up to it. I'm trying to collect names to see if I can put together a class action suit - let me know if you want to join me.
Bob
Old 01-01-2013, 09:44 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
You can remove the headlights. Search for a DIY the front bumper is held on by 4 bolts to the inner fender and 10 below on the plastic sheilds. and 2 torx screws. Eac headlight has 5 torx screws holding it in. Pretty simple to get at then just one wiring plug. You can remove the covers and see inside the light. Yours have some off a mounting that allows the motor to move them left to right.
You can do all this in about 3hrs.
If you like customer service. Don't look beyond a BMW.
Old 01-02-2013, 01:51 PM
E92-Lighting's Avatar
Mein Auto: 335i
same thing happened to a good buddy of mine with a 2006 300i.
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
adaptive xenon low beam, headlights
