Old 12-31-2012, 01:30 PM
BKnad BKnad is offline
Mein Auto: 98 528i
Unhappy will not turn over Please Help!!!!
Hello,
This is my first post, I need help!!
I have a 98 528i that will not turn over when i attempt to start it up. 2 days ago i started it up for about 10 sec everything was fine, i turned it off to add a little coolant. Once i went to turn it back on it would no longer start. I checked the oil and then i added a little oil. when i start it up if i push on the gas it will stay running but once i take my foot off the pedal it shuts off HELP PLease!!!
Old 12-31-2012, 01:47 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Keep it running with your foot for a few min and see if it levels out--I think it's flooded---neve crank the car up cold and run a short while and then turn it back off--they will flood this way
Old 12-31-2012, 02:34 PM
Mein Auto: 98 528i
thanks for the response. I kept it running for while with my foot on the pedal but it still cut off after i took it off. Is there anything else i could do??
Old 12-31-2012, 03:21 PM
Any codes? You did put the oil cap back on didn't you?--
Old 01-01-2013, 03:26 PM
Mein Auto: 98 528i
i cant check the codes i need to get the tool. but yea he oil cap is on
Old 01-01-2013, 04:25 PM
flyboyy's Avatar
flyboyy flyboyy is online now
I glow in the dark
Mein Auto: 2003 BMW 530i
cheapest test to check out is your battery... get a voltage meter and test the battery with the car off and test the battery with the car on. ? see the voltage reading. and post back.
Old 01-01-2013, 06:42 PM
Well if you have a code and can't tell us what the code is--we are at a loss to tell you how to make the fix on your car
Old 01-02-2013, 08:03 AM
Mein Auto: 98 528i
Hey man i'm back. I drove it up to auto zone. the codes that came back were from the MAF and the o2 sensor. Any ideas?
Old 01-02-2013, 08:34 AM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
Replace MAF and O2 sensor?
Old 01-02-2013, 08:40 AM
Mein Auto: 98 528i
I just cleaned the MAF and it still wont turn over. The o2 code is pre-cat i haven't replaced it. WOuld that cause it not to start?. i can drive it i just have to keep my foot on the gas at all times.
Old 01-02-2013, 08:43 AM
I am confused. You say it doesn't start, but then you say you can drive it by keeping foot on the gas.... Clarify, please.
If you are saying it doesn't idle - clean IAC valve.
Old 01-02-2013, 09:33 AM
Mein Auto: 98 528i
sorry, yes it wont idle. it will not stay on unless i push on the gas. is that an easy fix? (IAC)
Old 01-02-2013, 03:11 PM
Turn the car off--then unhook the maf and crank the car--if it stays at idle then you know the maf is bad--sounds though like you damaged the maf when you cleaned it--that is my guess at this point
won't start
