Dinan bracket to Powerdyne for an e36? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 12-31-2012, 02:43 PM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Ok folks. I am looking for some insight regarding mounting a powerdyne charger to a dinan bracket that I picked up. When buying it I assumed that the bracket would fit my car without too much trouble as its for an M3 and I have seen a similar setup on both the s52 and the m50.
I have an obd 1 M50. Im going to be running no intercooler for a few months. My goal is 5-6psi on a quietly styled 94 325. Im looking at the difference between the two and it appears that the bolt holes do not match up (There are more on the PD) and the angle on the Dinan bracket seems to swing out to the right at a 45 degree angle. Any pitfalls I should know about? Should I run 6 psi with stock internals and injectors will my car go explode like it was kicked by Master Shake?
I was figuring on bringing it to a machine shop and having them drill the needed holes, picking up a crank pulley online (5.25 I think?), 3.3 blower pulley, place the MAF ahead of the blower, boost guage and done for the time being.
Just to be clear I am not lookin g to set the world ablaze and all that ****. Just looking to bring the 3 into the modern world of acceleration. If my math is correct (which it probably is not) I should be putting down around 240 to the wheels (thoughts on this are welcome) .
I have been reading up for weeks but reading and doing are two very different things. Thanks in advance.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 01-02-2013, 05:09 PM
ReillyM3's Avatar
Moved to the e36 forum!
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1961 Falcon Tudor
