E36 (1991 - 1999)
Old 12-31-2012, 08:35 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Lol nice!!!!! Its cold here just no snow
Sent from my XT901 using Bimmer App
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 12-31-2012, 09:00 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Jessie you jelly?
Sent from my SPH-D710 using Bimmer App
-Dino
Old 12-31-2012, 09:22 AM
B1MM3R's Avatar
Jesse Moon Bayne
yes and no...if had e30 running right now then yes...for ol e36 no...lol.
Jesse
2001 330i DD
Old 12-31-2012, 05:11 PM
420flyboy 420flyboy is offline
Mein Auto: 328is
Just bought a used 97 328is for $1700 , feeling good about it
Old 12-31-2012, 05:16 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Nice! Auto or 5 speed?
Welcome to the fest!
Suggestion: get rid of the eyelids on the headlights. The car looks like it's dozing off.....
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-31-2012, 05:18 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Welcome aboard. I'm fairly certain your car will need a lot of work to get into good shape. We have lots of information for all of the most common issues and concerns listed in the stickies at the top of the E36 page. I highly recommend reading through all of it.
1998 BMW 328is
1966 Pontiac GTO
Old 12-31-2012, 05:41 PM
Mein Auto: 328is
Thank you , going through the forum now ,
I agree on those eye lids , don't like them myself.
Put new tires on today . Runs great , haven't found any problems "yet" lol.
Did get the brake circuit failure message tonight , pulled the fuse , reset it , I'll check the brake petal as all the lights still work.
All in all I'm pretty happy with my first BMW .
5 speed
Old 12-31-2012, 09:31 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Welcome to the 'Fest! You don't have to pull the fuse to reset a brake circuit failure warning. It will flash on the OBC for a bit after you shut the engine off, but it will be flushed the next time you start the engine if the fault isn't currently showing.
Brake light circuit is usually the brake light switch sticking. Common E36 failure.
Here's a DIY on how to replace it.
If your car has the OBC or the Check Control display you'll get the brake circuit failure notice even if the switch only sticks momentarily and then activates so the description in the DIY about no brake lights is when the switch has essentially frozen in place.
Old 01-01-2013, 12:16 PM
BMRfanatic's Avatar
Bimmer power house!!
-Dino
Old 01-01-2013, 01:49 PM
B1MM3R's Avatar
Jesse Moon Bayne
Nice Dino! Cell phone shots
ID:	355453   Click image for larger version
ID:	355454   Click image for larger version
ID:	355455   Click image for larger version
Jesse
2001 330i DD
Old 01-01-2013, 01:59 PM
dirty325is's Avatar
dirty325is dirty325is is offline
Mein Auto: 93 325is
Why can't people do things the right way garden hose laziness replacing that next any one see this kind of stuff before?
Sent from my DROID BIONIC using Bimmer App
Old 01-01-2013, 03:26 PM
BMRfanatic's Avatar
Lol very creative. I guess it does its job though?
Just looks real outta place
-Dino
Old 01-01-2013, 03:30 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
My 220d had garden hose for a coolant pipe. Apparently it was stock because all of the other 220d's that I saw pictures of had the same thing
Sent from my SCH-I405 using Bimmer App
-CJ
Old 01-01-2013, 06:55 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Looks more like heater hose to me. Who knows when it was replaced, hell it could have ripped in 2000 and instead of paying the 75 dollars or so it would of cost for that BMW OEM part, they just fixed it with a piece of heater hose. Who knows
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 01-01-2013, 06:58 PM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
If I were to do a rat rod, I would use garden hose for everything lol
Old 01-01-2013, 07:21 PM
ZeGerman's Avatar
Warm Leatherette
My guess is that garden hose doesn't hold up very well to oils & fuels, though.
1998 BMW 328is
1966 Pontiac GTO
Old 01-01-2013, 07:59 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
true. also not sure of the burst rate of garden hose, either. could be just green hose, though. it could also be a silicone hose for some air pump applications. i used green hose for that, which is high temp and *should* be resistant to oils and such.
df
Old 01-01-2013, 09:04 PM
dirty325is's Avatar
Mein Auto: 93 325is
That's how I bought it starting to leak oil from there recently rather have a legit part then something rigged and for it being my dd want it right and not have to worry about it much def learning more about these cars everyday nothing like them..
Old 01-02-2013, 05:59 AM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inze Fatherland 325
bumpers painted and installed! just need to install the hood and side skirts!
ID:	355586   Click image for larger version
ID:	355587   Click image for larger version
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 01-02-2013, 06:47 AM
BMRfanatic's Avatar
Spray paint the unpainted body before putting the skirts on. For extra rust preventing
Looka good so far otherwise
-Dino
Old 01-02-2013, 06:49 AM
jkmeisl's Avatar
Josh
the rockers have the factory rubber coating still on them. no need to paint
Old 01-02-2013, 07:30 AM
cj.surr's Avatar
some kid
Dat ride height? Went and bombed some curvy dirt roads. Felt like a rally driver
-CJ
Old 01-02-2013, 08:55 PM
B1MM3R's Avatar
Jesse Moon Bayne
Nice cj
Jesse
2001 330i DD
Old 01-03-2013, 11:24 AM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
As she sits today...
Testing out my rented 100mm f2.8L Macro.. in a non-macro application..
Mom's 328is and Dad's 1971 Chevelle SS can be seen in the background
Old 01-03-2013, 11:41 AM
ZeGerman's Avatar
Warm Leatherette
I guess I forgot that your dad has a '71 Chevelle. My dad has a '71 Chevelle SS454, too.
1998 BMW 328is
1966 Pontiac GTO
-*nga*-, :3
Similar Threads
Stop using http://216.7.191.102 already! alee Off-Topic 27 07-03-2003 04:48 PM
NY International Auto Show pics alee General BMW Questions 32 04-19-2003 07:44 PM
My Pics of new 330i Perf Pkg from LA Show Preview roup1 3 Series & 4 Series 44 01-29-2003 09:47 PM
My Pics of new 330i Perf Pkg from LA Show Preview (2) roup1 3 Series & 4 Series 18 01-05-2003 12:02 AM
