E30 (1982 - 1993)
Old 01-02-2013, 12:50 PM
Chaunceton Chaunceton is offline
Mein Auto: 1989 325i
Check Engine Oil Light
The check light by the instrument cluster blinks, so I check the lights above the rear view mirror, and the engine oil light is illuminated. I changed the oil about a month ago with full synthetic 5w-30. It drips a bit of oil, but when I check the oil, the oil level is right between the marks, right where it should be. How do I get that light off and/or solve whatever oil issue I might be having?
Old 01-02-2013, 02:02 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
your car is 20-25 years old, the sensor will be broken. you can short out the level wires which from memory is on the sump (been a while since ive worked on an M20) or if you want to fix it properly and maintain the warning system, you need to buy another float sensor. it is very unlikely anything is wrong with your car other than this.
E30 above Sold
Last updated 2nd January 2014
Old 01-02-2013, 02:47 PM
Thanks! I'll check out the sensor.
Old 01-02-2013, 02:48 PM
hornhospital's Avatar
D'oh, You Kids!
http://www.pelicanparts.com/cgi-bin/...88-91%29%20%20
$151.50 from Pelican. Personally, I'd short the sensor wires like Andy suggested. I keep a close eye on the oil level.
Quotes to live by:
BMW-CCA #441426
Old 01-02-2013, 05:07 PM
downhiller's Avatar
livin large
i ran into that problem a couple times from just running a lower weight oil (whenever i didnt change it myself, the oil shops put 5w-30 when i asked for 15w40 stupid twits).
Old 01-02-2013, 08:31 PM
Well, adding more oil seemed to do the trick, although I'm not sure why. The dip stick was indicating that oil levels were right on target.
Old 01-02-2013, 08:49 PM
downhiller's Avatar
livin large
i think that one is a level sensor
Old 01-02-2013, 09:00 PM
D'oh, You Kids!
Ha! You're right. My mistake. He needs an oil pressure sensor sender switch, not a level sensor. Completely misread what he was saying.
Quotes to live by:
BMW-CCA #441426
Old 01-03-2013, 07:25 PM
downhiller's Avatar
livin large
you were right the first time. quit second guessing yourself. tends to get you in more trouble.
Old 01-03-2013, 08:37 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
I don't think the level is meant to be between the two marks (halfway) as with some dipsticks. The level should be close to the top mark which is the full mark (but do not overfill it). I keep mine close to the full line to try and avoid oil starvation.
Old 01-03-2013, 09:49 PM
D'oh, You Kids!
Who said I was in trouble?
Quotes to live by:
BMW-CCA #441426
Old 01-04-2013, 03:45 PM
downhiller's Avatar
livin large
i didnt. i said second guessing does. like never second guess if your speed is correct going into a huge double on the bike or board.
Old 01-09-2013, 03:06 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
2 things:
Please keep oil between the indicated lines ! If the crank swhips around in the oil, because it is over full, you will know it after perusing your bank balance
The oil level switch, is actually 2- Dynamic & static
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
