#51
Sent from my PG86100 using Bimmer App |
#52
ranamunna
"I hope you are doing well. I didn't reply earlier because I wanted to gather all the information before replying to you. After I Changed the filter it worked fine for two tanks then now the on board gauge is not moving at all now from 0. Any guesses. As I wrote before the fuel level indiator strip is broke and repaired in the right tank if you are facing the front of the car. " You have not provided enough information for one to assist. When you say the guage is not working at all. Do you mean that its stuck at empty, half ro full irrespective of whether you fillup or not? """"fuel level indiator strip is broke and repaired in the right tank """ do you mean that the fuel sender unit with the float? The left one is easy to test if you are having issues with it. First provide clarity on this matter, and then will tell you what to do |
#53
hi
read your post the other day i have all the same symptons as you went and bought a fuel filter and was going to fit it this morning but guess what instead of a fuel filter i have a section of fuel pipe the same lenght as the filter in its place |
#54
That doesn't sound good. I can't even begin to guess the effects running unfiltered gas for any length of time would be. Hopefully nothing is broken.
'02 325Ci 5MT - Stahlblau - Xenons, aFe CAI, Scorpion Muffler, Racing Dynamics Strut Bar, PowerFlex FCAB's, 330i ZHP Shift Handle, BMW Performance SSK, M3 Dead Pedal, Sparco Alloy Pedal Covers (Now with Busted Brake Pedal Cover!), CDV-ectomy '02 Dodge Grand Caravan - Green - MEAN. GREEN. MACHINE. You aren't a man 'till you hustle a crapcan minivan around some corners with gusto. '05 Subaru Forester 2.5XS - Alpine White - Wife's whip |
#55
#57
ranamunna
What you are holding is the resistor, but looks like someone put a solder on it to link the tracks. Put it back on to the sender and connect everything back Please try this first, Test the intrument cluster and see if the fuel guage moves. If the guage moves then. under the rear seat, disconnect both the sender units. Put the key in and turn to ON but do not start observe the fuel guage. Disconnect the pump side sender unit/with pump and turn the key ON observe the guage. Connect the left side (with no pump), disconnect the pump side sender unit. Again turn the key to ON observe the guage Finally plug both sender units in and then, turn on and observe the Guage.. Provide the results and then will suggest the test and things to try |
#58
e90 320d
Hi,
I to have same issues with my e90 dying at 1/4 tank. The right side (pump) óf tank emties, but denying to suck from the left side of the tank. Anybody had the same problem with a e90 320d? I suspect the pump deying on me, and going to replade it. Just Wanted to hear from someone with a 320d facing/faced the same problem, before i go and buy a new pump. Thanks. Ps. The fuelfilter had been replaced. |
#59
My car is running normally(e46) but fuel gauge and OBC fuel Left in Tank readings is going up and down like a ------- Drawers with the same amount of fuel in it. If the cars acting normally and the gauge is up and down, does anybody think this is the senders?. How many senders are there on a 1999 saloon E46 and wher do I find them, I've no idea. HELP!!!
#60
Hello, it's me again from a bone. I've done the cluster test and the fuel gauge goes all the way from empty to full and back on the test. But i think it must be stuck inbetween empty and a quarter as it has 120 mile left in the tank, and it has because I've just put 4 gallon in it. Any thoughts would be much appreciated guys. Many Thanks.
#61
Above not a bone
#62
Hi Guys, where is the fuel filter on the e46????
#63
Posted Today, 09:04 PM
hi guys, my fuel gauge gives me false reading and is all over the place. I'm sure it's the sender unit. Can someone give me some pointers please. I think there is 2 sender units, am I right in saying one is attached to a fuel pump and the other on its own. I believe one sender unit reads the half to full on the gauge and the other reads empty to half. My car is never over half, so which one do I change. Are they universal and also can you detach the sender unit from the pump. helppppppp!!!!!! |
#64
OBC functions in a pdf so you can save it to your BMW file
Or print it out for your glove box |
#65
Thank you for the solution
I bought my 2004 E46 vert about three years ago. Since I first got it I had issues with gas flow around corners and slow accelleration. About 8 months ago I started running out of gas with the gage showing it still had gas. I searched the forums and found a couple threads but they all pointed at the sucking pump.
I had already had it at my mechanics shop and he cleared the sucking pump and decided it had to be the gage was wrong. He wanted to change the dashboard computer which thankfully I never had to pay for but I'm sure it was a lot of money. So this time when it ran out I had the tow truck take me to a gas station on the way to the mechanic and we topped it off. It only took 13.5 gallons to fill it so I knew there was at least a two gallons left. I'm not sure how I found this post just then but when we got it to my mechanic I asked him to change the fuel filter. He didn't think that was going to fix it but put it in anyway per my request. Well that was about three weeks ago. Twice now I have run it all the way down to one gallon and each time I topped it off to confirm it really had gotten down to that amount. You saved me so much money I can't thank you enough for taking the trouble to post this. I'm mostly a lurker because I don't have a lot to add - obviously - but I felt another confirmation that the filter fixed the problem was needed when you look at all the threads that end with "I'll just make sure it never goes below 1/4 tank." I should also tell you that it now is much faster off the line and never chokes out when taking tight corners very fast. It performs much better than it has since I first bought it. I highly recommend anyone having this type if issue change the fuel filter before spending any long green |
#66
And your pump should be next on your list if it's older than five years.
#67
Thanks so much, especially Tice03 for all the info. Unfortunately, I'm reading this now because I've already had the same problem and authorized the dealer to make the recommended repairs (fuel pump, fuel filter, and siphoning jet). The good news is that these posts totally validated the issue and the recommendation from the dealer (I never completely ran out of gas but started hesitating at 1/4 tank, so the problem wasn't quite as obvious). The bad news is that I've already agreed to pay over $1K to replace all the other recommended parts when it sounds like I should have started with just the filter.
They said I had metal shavings in the tank that likely have already compromised the fuel pump. Does anyone know if that's a common byproduct of running on low gas? Also - does anyone know what the same repairs (assuming I need all of them, not just the fuel filter) would cost at an honest auto repair shop? I'm not a DIY-er and the convenience of the dealer and getting a loaner car has prevented me from going elsewhere, but I've sunk way too much into the car lately. |
#68
If you get down to 1/4 tank and run out of gas, very likely is just your fuel pump. Forget about the sucking jet pump.
You might also need a fuel filter, but forget that temporarily if you just want to get going. But do the filter when you get a chance as this should be changed periodically. |
| Tags |
| fuel gauge, fuel gauge sensor, fuel pump, fuel tank, m54 |
