Old 12-29-2012, 06:32 AM
kitercarlos kitercarlos is offline
Mein Auto: X3 20d F25
F Series, problems in coding retrofit paddles
I'm investigation about retrofit paddle, I did all the hardware, paddles, wiring harness, etc. but I'm trying coding them, I tried both way, but I got nothing. The first was to coding SVT with 2TB and 7XA I got any error, but this configuration dont exist with 20d engine, here in europe its possible now to add paddles, so the second coding was return to automatic trans 205 and add 2XA, but mi X3 MY 2011, have this programmatíon in this Module ICM (CAFD_0000067B_002_002_0049) C_MF_LENKRAD, VALUE=INSTALLED, so disable the SALAPA element 2XA in all models F2X and F3X.
I dont know how uninstall re100813 that SA elimination 2XA en F2X, F3X, any ideas?
Old 01-03-2013, 05:57 AM
tankren tankren is offline
Mein Auto: 116i
did you mean the shift paddle? just VO code 2TB(delete 205) , that may works
Old 01-03-2013, 05:58 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
This discussion pretty much moved over here:
http://www.bimmerfest.com/forums/sho...d.php?t=664849
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 02-06-2013, 11:24 PM
kyj1014 kyj1014 is offline
Mein Auto: F10 528i (2011)
Hi~kitercarlos~ Could you do me a favor?
I have a f10 528i 6 cyl. without paddle shift. I want to retrofit my handle to M-Steering with Paddle. However I do not know how to connect the wiring paddle shifter.
Could you let me know that? or I do not need to make some wire for paddle shifter?
Is the wire already exist on my car? Thus, do i only need to put m steering with paddle on my car? Pleas let me know.
Thanks.
Old 02-08-2013, 12:49 PM
Hi Kyj1014
If you want to put paddles at your car, you will need to swap your steering wheel or to modify it to fit them. If your option is to put a M-Steering with Paddles (llike i did it), this one will have the harness to connect the paddles, but if your car hasn´t the rest of harness you will have to do it . In my car this one was missing and I have had to do it but by the moment, only the first part, I mean the part the back steering wheel (SZL module), because for now, I don´t know where it ends (CAS4, JBE·or ZGM), of course when you finish to do all the harness, you will have to coding your vehicule.
