E34 (1989 - 1995)
Old 01-01-2013, 12:24 PM
wooferbmw wooferbmw is offline
Mein Auto: 1990 BMW 525i
both rear door locks and rear window saftey button
Hi all! All of my locks work manually and can open all doors. When I use the key to lock and unlock the doors only the the drivers lock and front passenger lock move up and down electronically? Both rear locks will only work when used manually. I can unlock the car, open either front door and reach around and manually pull up and open the rear doors.
Is this a fuse/relay problem? Any suggestions?
The rear window safety button in center console does not work either. Can these issues be related? All the windows still go up and down with electronic controls.
Help needed.
Thanks!
Old 01-01-2013, 12:35 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
The first thing that comes to mind is a possible fault in the general module.
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-01-2013, 12:45 PM
That's under the seat correct?
Any idea about the rear window safety button?
Old 01-01-2013, 01:08 PM
BMR_LVR's Avatar
Humble E34 lover
Yes. It's under the seat. Since the GM also controls windows, it may be the cause of that as well or it may be a bad switch.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-03-2013, 01:21 AM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Make sure the GM is fully seated and that there is no corrosion at its contact pins.
MAke sure you disconnect the battery before removing the general module, it may get damaged by removing it while power is still going through it.
The next step after that would be to remove the rear door panels and check for voltage at the actuator connector when locking/unlocking.
Old 01-03-2013, 12:24 PM
Thank you Steve and paperpane94! I will check it out. I appriciate the help!
Old 01-03-2013, 08:47 PM
BMWFatherFigure's Avatar
Old School
+1 on terminal corrosion and bad earths. Are there signs some PO has 'fixed' the electrics? Some people don't repair to appropriate standards...........
Current:
E38 Parts Car
Previous:
