E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
High Battery Drain
I hope you all have been enjoying the holidays thus far.
I was wondering if any of you guys have experienced the high battery drain control message after a heavy rain storm? My car is parked outdoor in the driveway, no garage unfortunately and on extremely heavy down pour days, I get the high battery drain warning the next day. Any thoughts?
Good morning. I just had that problem this morning although last night's rain was not all that heavy. I have no idea what would cause it, so I don't have any solutions for you, just the same issue.
So I'm having a similar issue and encourage you to track down the Smart Charging fuse/relay in the trunk. It is apparently the culprit many times. Moreover the part is only $20 from BMW.
Read up on it here; http://www.bimmerfest.com/forums/sho...d.php?t=316911 Edit BMW Part Number; 6136-6901469
Thanks for the info, I'll check it out.
Thanks for the post reply gggunchi. I had a dead vehicle and thought maybe that relay was the culprit because I could hear it make a clicking sound when I had someone turn on the ignition switch. I disconnected the IBS connector and the vehicle started.
I may just replace that part too. OP, check your battery compartment for water. Check under the spare tire too. I ended up drilling to small holes under spare and one in battery compartment.
2006 530i Last edited by FCman; 01-02-2013 at 10:24 AM. |
Post pictures of the IBS connector. I'm working on a DIY for the thread. Hopefully admin with sticky it.
I will definitely post pics; however, I'm not sure what part I'm looking for, I need to identify which part exactly it is on the realoem schematic: http://realoem.com/bmw/showparts.do?...60&hg=61&fg=10
2006 530i |
Thanks for the insight fellas.
I have some maintenance to be done in the coming weeks, I will be sure to bring this up to my SA.
Ok, so here is the old negative cable w/ IBS
![]() Here is the actual IBS sensor on the underside of the negative cable ![]() Old cable side-by-side with the new negative battery cable/IBS sensor installed ![]() New negative cable/IBS with two additional new required connector/wires ![]() I apologize, I had intended on taking pics of the new IBS sensor prior to installation but totally forgot until it was already in - I was in a hurry. So here is the breakdown from BMW of San Diego: 12-42-7-603-567 Battery cable, nega $249.83 61-12-9-123-572 Adapter Lead IBS $34.78 12-51-7-615-476 Adapter for IBS $65.46 So it is a total of 3 parts, not two. Instead of integrating the cable coming right off the IBS sensor, it is now a separate required part at $65.46! That little change is a $66 kick in profit that looks like a $5 part - even the sales clerk was confused.
2006 530i Last edited by FCman; 01-03-2013 at 09:28 PM. |
