Old 01-03-2013, 02:11 PM
tohadamjo tohadamjo is offline
Mein Auto: 2000 540iA
Where do I order these clips?
More clearly, what is the part #???
1999 528iA - Oxford Green - 164,492 *Traded
2000 540iA - Titanium Silver - 232,XXX
2015 Jetta SE (Who cares cus this car sucks)
Old 01-03-2013, 02:14 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
realoem.com
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 01-03-2013, 02:24 PM
Originally Posted by mbell666 View Post
realoem.com
thank you, what are they called and or what is the part number.
Old 01-03-2013, 02:42 PM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
put the last 7 digits of your vin at realoem.com to find part numbers.
2002 530i
Old 01-03-2013, 02:50 PM
540nj 540nj is offline
Mein Auto: 03 540i6
Is that from the front inner fender? Or is this 20 questions?-)
Things like that are best at the dealer, the parts guy can find in seconds, and they're only a buck or two.
dave
03 540i6
Old 01-03-2013, 03:02 PM
If you use realoem you should be able to locate the part number. It a good site and i enjoy using it but not quite enough to go do it for you...
Pelican parts normally have a lot of the different clips/bolts available. Or as stated dealer is good bet if you have one fairly local. Possibly cheaper than buying online and paying shipping.
Old 01-03-2013, 05:22 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
Are they the pop rivets in the fender liner or the little 8mm screws
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 01-03-2013, 09:38 PM
Everyone gave you the answer we'd use ourselves.
1. You go to realoem.com and find your vehicle diagrams
2. You find the part number on those vehicle diagrams
3. You buy that part at the dealer (at least for clips)
If you want, once you have the part number, you can just google it.
For example, look at the part numbers for "my" fender well below (I have no idea if that's what your picture is though).
RealOEM.com Home => Select another car => Bodywork => Body - front body => E39 525i side panel front
Old 01-03-2013, 11:45 PM
dumblucky dumblucky is offline
Mein Auto: 99 528i
i found those on sleazeBay for cheap , took three weeks to get delivered from china but same same, try the us seller if you are ina hurry or visit the dealer , i myself just stocked up on the plastic screws , pop rivits , dooor panel clips, dash trim clips, door trim clips, glass cowl clips,engine cowl cips and plastic turn clips . each has its own diffrent part number and looks diffrent, prolly got $40 into plastic clips and fastners, ( including spares) but then again my bmw was in rought shaped fastner wise
