Old 01-03-2013, 02:47 PM
Kickback6 Kickback6 is offline
Mein Auto: 745i
Help with changing left upper control arm.
Can some one give me a quick tutorial on how to change out the front upper left control arm. What tools should I have and a step by step on how to do it. 2002 bmw 745i. New owner. Bought with issues.
Old 01-03-2013, 05:32 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Upper arm? you mean the thrust arm? You need to take the plastic pieces off, and then take the brake ducts out that cool the brakes.. then it's pretty easy.. the lower arms are actually easier.. those you just drop the ball joint and bolt/nut for frame and replace..
Old 01-04-2013, 11:29 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Yes. Go on ebay and spend $10 to buy the TIS.
Old 01-04-2013, 12:18 PM
Mein Auto: Nothing
Or do what I did and go on eBay spend $40 and get the cable, TIS, INPA, NCS Exp. and 5 other programs.. plus detailed instructions.
Old 01-04-2013, 12:25 PM
MOPAULY's Avatar
That works too, but you only need TIS for this.
Old 01-04-2013, 04:33 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
Please PM me the ebay link.
Old 01-04-2013, 06:00 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
can you post this info with the links/name of the seller here?
Old 01-04-2013, 06:25 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
This is the eBay seller that many bimmerfest members have bought cables and software from: bmwcables-co-uk
The cable is very reliable. The software comes with detailed instructions.
Here is the active product link: http://www.ebay.com/itm/121035001296
Tip: if you read the rating of this seller, you notice that many buyers didn't buy it at full advertized price. Make an offer!
Old 01-04-2013, 09:56 PM
Mein Auto: 745i
Thanx for the guidance guys.
Old 01-04-2013, 10:26 PM
Mein Auto: Nothing
This is the seller I bought from. Per referrals from here.
Old 01-05-2013, 12:21 AM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
How hard is it to operate the cable/ programs?
Old 01-05-2013, 05:51 PM
MOPAULY's Avatar
It takes a little time to setup the software and use it. Not hard if you are technically inclined.
Old 01-06-2013, 09:11 AM
Mein Auto: 745i
Where can I find a repair manual for this car ?
Old 01-06-2013, 01:24 PM
MOPAULY's Avatar
There is no 'repair' manual for this car. It's called TIS, and you can get the suite on eBay.
Old 01-06-2013, 02:38 PM
pedro2u pedro2u is offline
Mein Auto: 745i
I purchased TIS last week from eBay and still learning how to use and where things are. It's pretty good, well worth the $10, but I only found the lower control arm instructions , not the upper.
If anyone has found it, please share the path in TIS so I can better understand how to navigate
Old 01-07-2013, 04:32 PM
MOPAULY's Avatar
TIS should have everything - make sure you are navigating it properly. Personally I wouldn't touch this car without TIS.
Old 01-07-2013, 05:29 PM
Mein Auto: 745i
As I said, still getting used to navigating through this, but if you can tell me where you found the upper control arm, that would help a lot. Everyone has praised TIS, and I'd love to be able to get the most out of it.
Thanks for the help
Old 01-08-2013, 10:44 AM
Mein Auto: 745i
I got it from bmw
