Old 01-03-2013, 12:56 PM
drewski554 drewski554 is offline
Mein Auto: BMW 328i
Wheel/Tire Setup for 2011 328i
I live in the northeast and I'd like to get a pair of wheels, a summer tire, and a winter tire.
After lots of research and talking to ModBargains, I decided to go with this setup:
Wheels:
19" Avant Garde M359 Wheels - Black (link)
Front Wheel Size: 199 ET35
Real Wheel Size: 1910 ET38
Summer Tires:
Hankook V12 tires F 235/35/19 R 265/30/19
Winter Tires:
Blizzak tires F 235/35/19 R 265/30/19
Wheel Spacers (may or may not add):
H&R Trak+ Wheel Spacers - 5mm for Front/Rear (link)
Old 01-03-2013, 01:19 PM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
You'll probably have scrubbing issues in the front with 235/35R19s on ET30 at full steering lock - the tire will contact the forward fender liner. ET 33 rear should be fine but 265s on 10" wheels will look stretched just a bit.
e90m / ssii / foxred / nochrome
wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer
full challenge exhaust
WHEELS FOR SALE
Old 01-03-2013, 01:23 PM
Mein Auto: BMW 328i
I was told by ModBargains that this is the "perfect" setup haha.
Maybe someone else can chime in whether these dimensions will lead to scrubbing issues or not?
Old 01-03-2013, 01:36 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
19" snow tires in Boston? The potholes will eat the wheels and the tires alive. Also, you want thin tires, 225s or less, for running in snow.
Drop down to 16" or 17" Blizzaks for the snows. The $70 savings per tire on 17" will pay for the TPMS sensors, and if you buy a set of dedicated inexpensive alloy wheels for the winters you'll save $200/yr on swapping tires and be ahead of the game after 2 winters. It will go in an even better direction with 16" wheels. For that matter, fit the winters on the wheels you have now (assuming they're not a staggered 18" set).
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 01-03-2013, 01:48 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
this.
i doubt 19" rims and tires will survive a winter in boston. or spring for that matter. the potholes will destroy them.
16" rims-- they dont look bling but will be alot less succeptible to damage as well as being cheaper. or 17" snows on your existing rims.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 01-03-2013, 01:54 PM
Mein Auto: BMW 328i
Originally Posted by Orient330iNYC View Post
this.
You don't suggest 19" rims even for the spring/summer? I will definitely go 17" for winters, though.
Old 01-03-2013, 01:58 PM
CT's Avatar
CT CT is offline
GODSPD
I had it on my coupe. But with build tolerances being what they are, YMMV.
WHEELS FOR SALE
Old 01-03-2013, 02:01 PM
Zooks527's Avatar
I'm not a fan of the look, but if you are, I think they'd be OK once the potholes are filled in, assuming they don't rub.
Then again, sometimes it seems like the 4 seasons around here are:
  • Potholes
  • Big Potholes
  • LOOK AT THE SIZE OF THAT POTHOLE!
  • Filling Potholes.
Old 01-03-2013, 03:23 PM
summer and fall should be ok. but the winter, forget it.
i had 19s on my 2010 and 2007, had serious issues in NYC (which is slightly worse than boston, my brother up there has had serious pothole damage as well) untill i went with larger tires (~26" vs stock of 25")
for my F30 i didnt even bother with 19s. stuck with 18s and will probably upsize the aspect ratio to get more rubber between the rims and the road.
my winters are upsized 17s
Old 01-04-2013, 11:11 AM
ModBargains III ModBargains III is offline
Mein Auto: E92, E82, E46, E39
I wouldn't run the spacers on an LCI. Here's confirmation that it fits perfectly though:
And even when lowered:
Hope that helps! Pm me with any questions!
Sean Singh | Modification Expert | Sean@modbargains.com | (714) 582-3330 ext. 8009
BMW Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog!
Old 01-04-2013, 11:46 AM
tturedraider's Avatar
Freedom isn't free!!
19s may look cool, but they, tires and wheels, are more susceptible to road hazard damage and they will actually degrade road performance and ride quality. 18s will give better perfomance, ride quality, be less susceptible to damage, and be less costly.
www.bmwcca.org
Old 01-04-2013, 12:53 PM
Mein Auto: BMW 328i
Wow, thanks for the great respones! I've figured out my summer/winter setup:
SUMMER:
Avant Garde M359 Wheels 19" Silver [F: 19x9 ET35, R: 19x10 ET38]
Hankook Ventus V12 EVO K110 Tires (F: 235/35/19, R: 265/30/19)
WINTER:
Factory Wheels - 16" Silver
Bridgestone Blizzak WS70 Tires
Does that winter setup look good now? And what size tire should I go for with the winter setup?
Old 01-04-2013, 01:03 PM
Zooks527's Avatar
I'm on a new set of WS70s now, and they're great in the snow.
Something like 205/55-16 would seem to put you in the right ballpark. I'd confirm it with someone like the guys from TireRack before buying (i.e. - will that size fit on the factory wheels, or should you go with 225/50-16). Because of the larger brake rotors on the 335, I'm running 225/45-17, but with factory 16s, you should be able to get narrower. Best snow performance I ever had was on 195s on my old Passat 4motion.
Old 05-31-2013, 07:21 PM
Carlitodontcare Carlitodontcare is offline
Mein Auto: 2011 328xi
I have 328xi. Whts the best wheel size for a daily driver and can i get the wheels staggered.. 18s or 19s
