E34 (1989 - 1995)
Old 12-23-2012, 10:14 AM
amcole amcole is offline
Mein Auto: 1993 BMW 525i
battery is dead.....doors wont unlock
Good morning BMWPEEPS....
I have a probelm. I have allowed my 525i to sit for about a month without starting him. I tried yesterday but the battery is dead. I can only unlock the front passenger door. I have tried to boost the battery from under the hood and nothing is happening. I cant get into the car to get the battery out from under the rear seat...........please help I am a girl and my mechanic is out of town for the holidays!! Merry Chrsitmas and Happy New Year!!!!
Old 12-23-2012, 10:41 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Are you sure that you are making a good connection on the post under the hood (remember you must pick a good grounding point)? Remember, with a totally discharged battery, it may take a few minutes of charging (while the jumper cables are connected - with the other car running) to get enough juice in your battery to turn your engine over. Even if you can't jump start the engine, it should give you sufficient voltage for the central door lock system to work and unlock the doors thereby making access to the rear seat so much easier.
If you are able to access the cabin by unlocking the front passenger door, then you should be able to get to a position to raise the back seat. Just grab the front of the rear seat at the bottom (about arms width apart) and YANK it upwards. This should allow you to access the battery, even though you are unable to get the rear seat out. It will take some tricky maneuvering on your part.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 12-26-2012, 09:04 PM
BMWFatherFigure's Avatar
Old School
If the driver's door lock can be turned with the key then it can also be unlocked form the inside as the dead-lock function is mechanical. Poster has passenger side access so also has driver's door access.
Bonnet and boot also accessable (OK hood and trunk for those needing a translation). A big 12v battery will restore lock function - apply in engine compartment. DONE!!
Current:
E38 Parts Car
Previous:
Old 01-04-2013, 10:44 PM
virgontour virgontour is offline
Mein Auto: 535i
baby ya cant use [ im a girl ] if you can start the beast let it run for 10 or 15 minutes ,go make ya self a cup of tea while its running, just make sure everything is turned off in the car ,just to give the poor thing a chance. if worse comes to worse go to another mechanic there must be more than 1 in memphis,,, cheers babe have a good 0ne.......
