Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series / 2 Series > E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135.
Old 01-04-2013, 10:57 PM
vino007 vino007 is offline
Mein Auto: 135i
FS: Stett Charge Pipe w/ Tial Blow off Valve N54
Selling my Stett Charge pipe with Tial Blow off valve for 135i or 335i for N54
it s a must have for any turbo cars... it is worth 600$ + taxes + shipping. I am asking 350$
from Montreal, but can ship anywhere
514-247-8466
Vinh
also have a JB4 with OBD2 cable and Active Autowerke for sale as well
here are more info on this parts
Item #: SP11-220180
The factory plastic charge pipe and diverter valves are prone to leaking under stock boost levels, increasing boost only makes this problem worse. The stock diverter valves are not designed internally to handle added boost pressure. They can fail under load which will actually cause boost bleed off when you don't want it causing boost spikes and loss of horsepower. The STETT Performance N54 135i/335i charge pipe is made from 100% 304 stainless steel and designed to handle higher than stock boost levels without leaking thanks to it's very strong design, ultra high quality materials and our patent pending throttle body connector that forms an ultra tight seal and prevents the charge pipe from blowing off as is so common with other products on the market. The factory plastic piece begins to leak on even stock level boost. Simply using a standard silicone hose connector to connect an aftermarket pipe leaves a high chance the pipe will blow off the engine. We, however, developed a patent pending 4 ply, double layer hose connector to the throttle body which is far superior to anything else on the market including the factory flimsy o-ring and lock clip. Each kit comes with everything you need for installation including the billet aluminum BOV from Tial, one of the most respected names in the industry. Each pipe comes standard with dual stainless meth bungs.
Proudly made in the U.S.A.
Sound Clip: HERE
- 304 stainless steel replaces factory plastic
- Ultra high quality and strong materials
- Eliminate leaks caused by weak factory connections
- Get back horsepower lost from weak factory diverter valves
- Our patent pending hose connector eliminates pipe from blowing off engine under load
- Dual stainless Meth bungs
- Extreme Duty silicone hoses
- High strength stainless hardware
Old 03-18-2013, 10:02 PM
The black pearl The black pearl is offline
Mein Auto: 135i
Do you still have this for sale?
Old 03-19-2013, 10:56 AM
Mein Auto: 135i
everything is sold! thanks for your interest but don't know how to remove the thread
