#26
Re: OK Heres another couple questions for you
Pin 13 and 14 are for the HK Traffic Pro NAV system radio. It's a mono input. 13 Low frequency input. 14 Ground. |
#28
As an aside, I plan on putting a hands free kit for the v60 (basically same kit at the T720 kit) in my m roadster. I've read this thread, but I'm a little confused. The antenna/telephone amp -- where is it? Does it use the standard antenna or do I need to order a different one? I imagine this replaces my standard antenna out back. Are the pins that go into the 8 pin mating connector the same ones that go you order for the back of the radio or is it a different part number? Last edited by TxnBluDvl; 08-06-2003 at 09:58 PM. |
#29
>>>My coupe came with the telephone antenna. The connector is in the console area. Not sure what the roadster has. Are the pins that go into the 8 pin mating connector the same ones that go you order for the back of the radio or is it a different part number?[/QUOTE] >>>Same pins male and female. |
#31
Have any of your looked into Bluetooth phones?
Sony Ericsson (and several others) have hands free aftermarket kits that will radio mute, amoung other things. The S-E kit has a small controller you can mount to the steering wheel (no wire due to Bluetooth) that controls the phone for answer, hangup, or scrolling through the phone numbers programmed into the phone. The S-E T68i phone which I have also supports voice prompt dialing of numbers in the phone.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
#32
[quote=Ron Stygar;224906]
RON WHAT IS THE MATING PIN NUMBER FOR THIS CONNECTOR?
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
#33
[QUOTE=bob lindquist;2324418]
#34
[quote=Ron Stygar;2325113]
do they come terminated? the cell connector down in the console is a great place to tap switched and always-on power. if you tap the console bulb line you also have dimmed power.
#35
[QUOTE=bob lindquist;2325127]With wire attached.
#36
[quote=Ron Stygar;2325130]yes. I find its hard to beat a factory crimp. I'm better with solder and shrink
#37
[QUOTE=bob lindquist;2325135]61 13 0 007 452/3 S/L
#38
[quote=Ron Stygar;2325139]
61 13 0 007 452 S/L 61 13 0 007 453 S/L (LARGER GAUGE) WHATS THE S/L STAND FOR?
#39
[QUOTE=bob lindquist;2325151]
453 = large pin |
#40
[quote=Ron Stygar;2325154]THANKS. WHAT YA WORKIN ON?
#41
[QUOTE=bob lindquist;2325160]Right now I'm checking my 318ti for the emissions readiness bit.
Will be taking it for emissions check next week. |
#42
Now I'm back workin in aerospace I have weekends off. yippe. I'm starting to get back into the mods.
#43
which BMW tool do we use to remove these pins.
#44
See post #13.
#45
OH GOODY, SAME PINS AS THE SUNROOF SWITCH. I HAVE THAT TOOL
#46
Ron,
Great write up, motivated me to do the same. I have all the parts on hand, though I'll be using a Grom adapter for the Bluetooth operation with my Business CD. One question though, do you have a measurement from a point of reference for the cut you made in the headliner? The template you show will be useful, just not sure exactly where to place it so that the screw hole lines up properly. Something like a measurement from the cabin light. Hope that makes sense. Thanks! |
