Old 12-11-2012, 07:58 PM
blakedanatural blakedanatural is offline
Mein Auto: 2005 645 ci convertible
Diy info
Hello All,
Does anyone have a DIY for installing a expansion tank and the O ring on the tempature sensor? It would be greatly appreciated because I am still trying to eliminate a coolank leak. I replaced the upper expansion hose( thanks Herbp) because it had a small crack on the plastic portion of the hose. This was done Monday and today i checked the tank and it was low( I topped it off with BMW coolant on Monday) and I noticed a minor stream of coolant leaking from the passenger side wheel well. After searching the forum I discovered that a leaking expansion tank and O ring from temp sensor was a poplar issue with the 645.
Thank you for your time and consideration Bimmerfest. I'll PM a few people also if the forum can't help.
Blake
I have to get this done while the weather is still in the 40's so your prompt attention to my request would be hugely appreciated. Funny thing though guys the car never ran hot/overheated and I drove it for at least 1.5 hours before discovering leak. Is there a overflow hose connected to the tank and I possibly over filled the tank? The tank should stiil be filled at the top even after driving for that long correct? Sorry for all the blah . Someone help !
Old 12-13-2012, 01:14 PM
Diy
I would like to thank Herbp and Yorgi for all your help with me installing the expansion tank. It to
ok me about 2 hours but I did it. I took the car for a 1 hour drive and came home to inspect for leaks. After the car cooled down i CHECKED AGAIN AND EVERYTHING IS GOOD. After installing the expansion tank I topped off with BMW coolant and I'm good to go.
Thank you,
Old 12-13-2012, 05:21 PM
HerbP HerbP is offline
Glad to see all is well!
Old 12-13-2012, 07:30 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Good job.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-16-2012, 03:45 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
Hey, Found your post Glad to know the expansion tank worked good
Originally Posted by blakedanatural View Post
Hello All,
Blake
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 01-05-2013, 10:03 AM
DBLAZE's Avatar
DBLAZE DBLAZE is offline
Mein Auto: Alpine White F01 750i X
I just replaced my Expansion Tank last weekend... It only took me about 20 minutes from start to finish and I didn't need any tools whatsoever. The top and bottom portions of the tank split when the car reaches a certain temperature and you could see coolant spewing down the sides of the black tank. All you have to do is remove the 3 hoses and the electronic connector. I only lost a little bit of coolant during this repair, but I did buy a whole gallon from the dealer as well.
BMW F01 Alpine White 750i xDrive; Oyster Interior
[BMS Stage 1 Tune | VRS Front Spoiler | AC Schnitzer Trunk & Roof Spoilers | AC Schnitzer Pedals/Footrest | 45% Tint]
BMW E63 Jet Black 645ci - Retired
BMW E46 Fern Green 323ci - Retired
