Old 01-04-2013, 06:56 PM
ill540i's Avatar
ill540i ill540i is offline
Mein Auto: Bmw 540i
How to flush the radiator ?
I have a 98 540ia and I feel like its time for a flush just got the oem Bmw coolant,just need help on how to flush it thank you.
Sent from my MB502 using Bimmer App
Old 01-04-2013, 08:53 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Why do you think you need to flush it? Do you suspect clogs? If the rad has more than 100k on it, it's due for replacement.
Just drain the rad and the block (pull both block plugs), and fill with 50/50 mix of distilled water. Be sure to carefully follow the bleeding instructions.
Old 01-05-2013, 08:59 AM
Most of us replace it well before it would need flushing.
If BMW knew how to design radiators, then maybe we'd get a chance to flush it - but - otherwise ... naaaaah.
BTW, here's the picture of the inside of 'my' radiator ...
- Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2) & request for another autopsy (1)
Old 01-05-2013, 02:35 PM
ill540i's Avatar
Mein Auto: Bmw 540i
I replaced my radiator about 15k miles ago but since then had low coolant warning twice and the float doesn't raise up anymore plus I topped it of with tap water which I know im an idiot for doing :sly:
