Seat not locked error - Bimmerfest - BMW Forums
Old 01-05-2013, 12:41 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
For the past few weeks I've been getting the "DRIVERS SEAT NOT LOCKED"
pop on my info screen. I clear it by pulling the seat latch up and let it down just once. It will go away for a while till I hit a hard bump or I move to stretch in my seat.
Has anyone seen or fixed this before? I don't want to tear down my seat if there is an easier solution. Thanks!!!
Sent Via iPhone using BimmerApp
Old 01-05-2013, 01:59 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Hi! Whilst I have not had that direct fault I have had the release cable for the seat break or at least the plastic ends break. I had to take the seat to bits to replace, but did notice in my 3 or 4th attempt to get it to latch that once the actuator starts to fail due to I think cable stretch you have to replace the whole lot. Not a difficult task as you remove the rear plastic seat back and the lower seat covers on the side where the switches are. Be careful how you remove this as it is easy to break a lug!!! If memory serves they are not straight pulls but slides!! hope this helps a little!!!
Old 01-05-2013, 03:09 PM
Tinoxx Tinoxx is offline
Mein Auto: E64 650I CAB
Hi
I had this problem it was a little sensor in the seat which cost about 30, when it was replaced it solved the problem. Does it say anything about airbags?
/Users/vc_autos/Desktop/IMG_1603.JPG
Old 01-05-2013, 03:17 PM
Nitrogen's Avatar
Nothing about airbags just the seat.
Did you do it yourself if so how do I get to it to replace it?
Old 01-15-2013, 11:20 PM
Nitrogen's Avatar
Well I opened up the seat and took a look to see where the sensor is and what I found is a micro switch that gets pushed when seat is locked in place. Problem is that sometimes the switch moves over and becomes free and opens then I get the seat not locked error.
I really can't see anyway of getting to the switch without taking the seat out.
Old 01-09-2014, 08:12 PM
jamesmanning jamesmanning is offline
Mein Auto: m6
did you figure this out? im having the same issue. what sensor is it? can you take a pic or find a pic online to post?
Old 01-09-2014, 08:40 PM
Nitrogen's Avatar
I did figure it out! I took the side of the power seat off and I found the switch and I just zip tied it closed. Only thing that I suffer from by doing this is the head rest doesn't go down or up when you fold the the seat down. I didn't care about that feature as long as the dinging alarm went away it was so annoying. I will look for the pics I took a lot of them.
Old 01-10-2014, 05:26 AM
Mein Auto: m6
pmed you...
Old 01-10-2014, 01:54 PM
Nitrogen's Avatar
Here are some pics sorry for the bad quality but I was using my phone.
Hope it helps once you have the face cover off you can see what needs to come off.
ID:	416390   Click image for larger version
ID:	416391   Click image for larger version
ID:	416392   Click image for larger version
ID:	416393   Click image for larger version
ID:	416395   Click image for larger version
ID:	416396   Click image for larger version
ID:	416397   Click image for larger version
ID:	416398   Click image for larger version
ID:	416400   Click image for larger version
ID:	416401   Click image for larger version
ID:	416402   Click image for larger version
ID:	416403   Click image for larger version
ID:	416405   Click image for larger version
ID:	416406   Click image for larger version
ID:	416407   Click image for larger version
