Old 01-03-2013, 07:11 PM
drewski554 drewski554 is offline
Mein Auto: BMW 328i
3-Stage Intake Manifold for 328i
Hello --
What parts are needed for the 3-Stage Intake Manifold for 2011 BMW E90 328i?
Please don't tell me to use the search button. That's all i've been doing for the past 30min, there's no links or references to parts #s. If someone could PLEASE help me out, it would mean a LOT.
Thank you.
Old 01-03-2013, 07:46 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
There are a lot of threads on it here
http://www.e90post.com/forums/forumdisplay.php?f=35
see second sticky.
duplicate sorry how come there is not way to delete even in advanced mode.
Old 01-03-2013, 07:49 PM
There are a lot of thread on it here
see second sticky.
And since it was only made for an 06 330 there is only an 06 one unless
they have continued them in Europe.
Old 01-03-2013, 07:54 PM
Mein Auto: BMW 328i
Thank you sir, I appreciate the response!
Just to clarify, I CAN do this mod for a 2011 328i Sedan, correct? Some member said something about the 328i now having this 3-stage intake manifold, and so now im basically mind****ed
Old 01-03-2013, 08:08 PM
Cultr Cultr is offline
Mein Auto: E92 335i
Depending which 328i you have you may already have e three stage intake
Old 01-03-2013, 08:13 PM
Mein Auto: BMW 328i
How would i be able to verify whether i have it or not?
Old 01-03-2013, 08:28 PM
ND40oz ND40oz is offline
Mein Auto: 09 135i
Depends on if you have an N51 or N52, pulling your build options with your VIN should tell you.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 01-03-2013, 08:32 PM
Mein Auto: BMW 328i
OK, thanks for the help.
If I end up getting the N51 engine instead of N52 engine, what N52 parts will NOT BE COMPATIBLE with N51 engine?
And what engine is preferred: N51 or N52?
Old 01-03-2013, 10:57 PM
As far as I know only the 330 had it.
The guys on the normally aspirated board on the link I provided are likely to know.
What is this n51 I keep hearing about as far as I know the n52 with the 6 hasn't had any major changes since 07 . The US horsepower hasn't changed since then until they went to the 4 in the f30 in the US.
Found this
http://www.e90post.com/forums/showth...&highlight=n51
where I expected I would.
Old 01-04-2013, 08:03 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
http://www.e90post.com/forums/showpo...40&postcount=5
Old 01-04-2013, 12:32 PM
Mein Auto: 09 135i
Originally Posted by ctuna View Post
What is this n51 I keep hearing about as far as I know the n52 with the 6 hasn't had any major changes since 07.
The N51 was used in vehicles with a SULEV rating, the N52 was used in ULEV vehicles.
13 Honda Insight EX
Old 01-04-2013, 09:32 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
If your engine has a DISA valve, then you have the multi-stage intake manifold. This is identified as an "adjuster unit" (part #2) in the diagram linked below:
http://www.realoem.com/bmw/showparts...56&hg=11&fg=40
My car has the N51 engine, and it has the DISA valve and the multi-stage intake.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 01-04-2013, 10:59 PM
Does this mean all it lacks is software to make it a 330
Does this mean all it lacks is software to make it a 330 ?
Is it the same 3 stage intake and manifold as the 330?
How do they use the Disa valve in the N51 ?
I have seen some NA x3's listing 260 hp output I think.
this should tell you whats in your car
http://bmwvin.com/
looks like the same part number according to the n51 vs n52 thread.
Old 01-05-2013, 12:39 AM
1zamboni 1zamboni is offline
Mein Auto: 2013 E93 & 2014 F30
How are going to going to get the shop to reprogram it for you? Unless you have connection none of the shop can reprogram your vehicle from 325 to 330 with multi stage intake.Give it up you are wasting other time doing a mod which is impossible.If that was so easy no one would buy the 330i just get the 325i and convert it to 330i.
2014 F30 335i Melbourne Red
2013 E93 M3 Melbourne Red
2012 E93 Space Gray (Retired BMW buy back)
2009 E82 ( Sold )
2006 E90 ( Sold )
2001 E46 ( Sold )
My next vehicle would be a Zamboni
Old 01-05-2013, 05:37 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
Canadian 323i too (at least 2007+).
Old 01-05-2013, 07:22 AM
You are correct. The E83 LCI's got the base X5 engine:
Old 01-05-2013, 07:44 AM
So that would be the software to get
along with the three stage input if you could though some of those
tunes seem to be approaching that region to.
Old 01-05-2013, 12:20 PM
avocet avocet is offline
Mein Auto: '07 328i
It is an effective and satisfying mod. There are guys with 325's that have had great results with the 3 stage and aftermarket tunes(AA comes to mind).
On my 328 with just a bms, the 3 stage is a great mod. Does it make it a 330? No. The thing is plug and play. Plug the disa motors in and they just work. Do I think I will give a 330 a run for its money? Yes. Recreational testing with a dynoliscious indicate a few tenths here and there. Am I having fun with this? Yes I am. Therefore, it is money and time well spent for me. It is called enthusiasm.
With patience, parts can be aquired quite inexpensively.
It is not a wase of time, nor is it impossible.
Old 01-05-2013, 06:53 PM
You think you can out do BMW engineer on this mod ?
2009 E82 ( Sold )
2006 E90 ( Sold )
2001 E46 ( Sold )
Old 01-06-2013, 12:21 AM
Mein Auto: '07 328i
so you changed your suspension?
exhaust?
brakes?
seat?
wheels?
steering wheel?
springs?
sway bars?
lighting?
intake?
ecu?
but what about the bmw engineering????!!!!!!
whatever.
