Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 10-03-2012, 05:24 PM
Snaggy Snaggy is offline
Mein Auto: Audi S6 Avant
2011 335D tire pressure discrepancy?
I've got a sport package with 18" wheels and there is a discrepancy on the stickers on my door with regards to tire pressure specs. The white sticker indicates PSI of 35/42 front /rear. The small yellow sticker below it indicates, "for speeds up to 100 mph", 42/51. It seems to me that the yellow sticker might be incorrect since the manual also states 35/42. All my tires are low( significantly so) compared to the white sticker, so I don't know which one to top off to. Searching the forum many guys are going with 36/36.
Thoughts/ suggestions?
Thanks,
Dave
Old 10-03-2012, 08:29 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
The yellow sticker is for speeds *OVER* 100 mph, not below.
Use 35/42.
Old 10-04-2012, 03:58 AM
floydarogers: Thanks for the reply. Common sense told me that your statement is correct. I was just confused that the label is confusing since it states:
"use inflation pressure specified ABOVE (they are listed below??) UP to 100 mph only" How would you interpret that? Regardless, i intend on using 35/42.
Old 10-04-2012, 04:24 AM
ChasR ChasR is online now
Mein Auto: 335d, E28 M5, Clubman S
Above (toward the roof) the yellow sticker with the statement "Use inflation pressures specified above up to 100 mph only" is a white sticker that states the "normal" inflation pressures. The yellow sticker goes on to state tire pressures for speeds over 100 mph. Seems pretty clear unless you use the text allignment to determine where above is.
Old 10-04-2012, 04:35 AM
ChasR: You are absolutely correct!! I am just being pretty dense!! I should have read it more carefully.
Old 10-04-2012, 04:48 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
currently 34/40 I like to race from time to time
Old 10-04-2012, 10:16 AM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
I run my Michelin Super Sports (non-RFT) in the 40/42 range.
Old 11-04-2012, 05:58 AM
badgerbob badgerbob is offline
badgerbob
Mein Auto: 2011 335d
It took me some getting used to, but I have settled on 35/42 as best all around.
Old 11-05-2012, 12:17 PM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
I run 32/35 (non sport)
Sent from my MB525 using Bimmer App
Old 01-06-2013, 06:16 AM
badgerbob
Has anyone noticed if the tire pressures affect gas mileage on this vehicle? I get pretty much right on 36-37 mpg on the highway, but see some getting 40 mpg plus. Other than speed I am wondering what others have found that may influence mpg.
Old 01-06-2013, 06:57 AM
KeithS KeithS is online now
Mein Auto: '11 335d, '00 540iT
MANY factors impact MPG
  • Size of tires - bigger tires use more fuel
  • Tire Presssue - more pressure improves MPG but deteroriates ride quality
  • Software version in the DME
  • Ambient Temperature
  • AC use
  • How heavy your right foot is (accelerating faster vs slower)
But acutally I'm not sure about the last one. I have a feeling that with the D if you accelerate up to speed quickly then get into cruise/maintain speed mode sooner, that it uses less fuel than accelerating very slowly delaying getting into the maintain speed mode.
Old 01-06-2013, 07:00 AM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Terrain is also a big factor. I could get close to 40 mpg with my d on level roads at 65-70 mph. On my daily commute to work at the same speeds, I had to climb 2 "mountains" of about 1000 feet each and could never get more than about 34 mpg.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 01-06-2013, 07:29 AM
Cold starts take a big bite out of fuel mileage as well. My daily commute of 20 miles on a warm engine results in about 36mpg. With a cold start thrown in at each end mileage drops to about 34. Overall average is 33.22, lower than the commute due to traffic in my drives between commutes.
As for accelerating fast vs slow, I believe in a diesel, slow works best. In a gas motor however, accelerating slowly means the engine sucks vacuum against the almost closed throttle plate, decreasing the efficiency. You get better mileage by mimicking diesel throttle function (no throttle plate) by accelerating briskly (opening the throttle plate) and short shifting. Hard to do in an automatic, though that may be why some manufacturers (Hundai come to mind, but not BMW) program in an abrupt throttle tip in, to max mpg on the EPA city cycle. Real world the driver compensates and mileage suffers.
Old 01-06-2013, 08:26 AM
Pasa-d Pasa-d is offline
Mein Auto: 335d
I don't know how much effect it had, but I used that technique in my old Audi S4 (the twin turbo model). For example, leaving a stop light on a 35 mph marked street, I would floor the gas pedal and use the manual shift feature of the tiptronic to work quickly up to 4th or even 5th gear. The acceleration would be brisk, but not law enforcement attracting, with very little noise from either engine or tires (thanks to a stock exhaust system and all wheel drive). As soon as I'd hit the speed of the street I'd back off the throttle and cruise from there. It's a very stealthy way to get rapid acceleration without the attendant "racing noise" of high engine rpms. Still barely managed to eek out 21 mpg on average though.
Of course, I can't use this technique in "the d" without leaving darkies all the way across the intersection!
'11 335d M-sport/Le Mans/Oyster/Glacier/Titanium angel eyes
Lifetime avg fuel economy: @27,000 miles, 35 mph, 28.0 mpg
Pollution is bad, but carbon isn't pollution!
