AUX enable code ? - Bimmerfest - BMW Forums
Old 10-08-2012, 05:13 PM
bkc0508 bkc0508 is offline
Mein Auto: 2006 750LI / 2012 2500HD
AUX enable code ?
I am trying to get aux working on my e 66
I have read this post
http://www.7-forum.com/forum/3/hat-e...137506-14.html
INST_ID_TUNER tuner_vor_0905
I have enabled aux in my mmi but its does nothing when i select it. I can find
INST_ID_TUNER
iboc
In my .trc file that I did a complete backup of my car.
Does anyone know should I change the iboc to tuner_vor_0905
Also does any know what ECU this is in.
Old 10-08-2012, 10:32 PM
KingSilverback KingSilverback is offline
The Silverback
Mein Auto: 2006 750Li
You have the cable installed already?
Old 10-09-2012, 03:45 AM
Yes I have the cable
Old 10-09-2012, 08:13 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Once a music source is plugged in, you should be able select AUX in the Entertainment menu.
Old 10-09-2012, 08:39 AM
I had it cabled in and still no working. I think I may have a early facelift ask and it's just not going to work.
Old 10-11-2012, 10:30 AM
The Silverback
Did you figure out what the problem was?
Old 10-11-2012, 10:38 AM
i have put it on the back burner for now... I am getting SSS setup right now I am going to update the files on my car with the v46 daten files and then I might go back to looking in to it.
Old 10-11-2012, 02:12 PM
The Silverback
If it doesn't workout and you decide to sell your aux cable lemmie know
Old 01-06-2013, 11:52 AM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Did you get this working yet? Just activate aux in the MMIGT module
Old 01-06-2013, 12:23 PM
The Silverback
With some facelift ask units it's not as simple as that, bought the aux cable, enabled aux in mmi and it still didn't work. I'm gonna pull up the ask trace file later and see if something needs to be changed in there as well because as far as I know all facelift ask units are electronically similar.
Sent from my SPH-L710 using Bimmer App
