Old 12-06-2002, 10:26 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Z3 Heater operation
When you move the heater temperature control knob off of the minimum temperature position, it closes a switch and opens the heater valve. This sends water to your heater coil (core).
On the M's, it also shuts off the auxiliary water pump.
If you continue to turn the heater control knob, it reduces the amount of outgots air bypassing the heater core. Outgots, is air coming in. Ingots/outgots came from where I used to work.
At work, ingots was the indoor temperature. Outgots was the outdoor temperature.
So if the outgots air is really cold, the knob ends up at the maximum temperature position.
Old 12-08-2002, 01:35 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Re: Z3 Heater operation
Funny, where I used to work (and from another former Boeing guy...) we had "goes-inna's & goes-outa's".
For us, goes-inna's was the input signal (or voltage) and goes-outa's was the output signal (usually 4-20 ma).
Different part of the country, I guess...
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 01-06-2013, 11:58 AM
hwatson hwatson is offline
Mein Auto: 2001 BMW Z3, 2.5i
How do you test the water valve control switch?
Old 01-06-2013, 01:03 PM
Ron Stygar's Avatar
19,585 Miles
Valve
From Z3FAQ:
http://www.bimmerfest.com/forums/sho...1&postcount=67
Old 01-06-2013, 01:19 PM
Thanks. This helps a lot.
Henry
