E34 (1989 - 1995)
#76
Hi please this is a threadjack but you did not state if you have spark, if you dont your izsue is likely the crank sensor, please do start a fresh thread will not respond further to you here, cheers
#77
If you are talking to me, my sincere apologies...thought very same problem so not a thread jack...seems shame to start new thread with all very same issues and symptoms tho yes little different model and year. Again, apologies :embarrassed:
#78
To pkquest and Rick, I've not heard of timing chain failure on a M60 before, but it certainly is possible. One member here had a M50 that snapped its chain. It was the first time I had heard of it on the robust M50. Are you able to see the rocker arm assembly on one bank if you remove the oil filler cap? If so, have someone crank the engine over and ensure that the valve assembly is turning. My presumption is that it is turning or else the piston would be hitting valves (if the M60 is an interference engine). Plus, I would think that it would be making a horrible noise if the timing chain broke. Hopefully, you can mark this off of your worry list. pkquest, you indicate that your compression was good after adding oil in the cylinders. How was it prior to that? Rick, have you checked the compression on your engine? Have either of you determined if you have the Nikasil block? I would not think that this would be the problem because they usually start having problems slowly and manifest with symptoms. It sounds as if both of you had a sudden no-start. It's just another thing to check. Rick, it may be that you may wind up having to take your car to a BMW mechanic for a diagnosis.
Steve Calypso Red 1992 525i with 170K miles, fresh coolant system overhaul Nov. 2010 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
#79
Or perhaps we could have a giant no start thread and ask people who start a new one to just begin tagging along on that instead ? Anyway, to anyone new here, please download the Bentley manual and its troubleshooting tables summary and go from there. See you in a new thread.
#80
YES, tested both banks....all 8 cylinders and all 8 spark plugs and all 8 ignition coils.
On the cranking I crank it till the cows come home and am POSITIVE that I have good hot strong repetitive spark on all 8 cyllinders. Thanks for the help! Quote:
#81
Hey Steve,
I read this but don't think I replied. This is a great suggestion and certainly a possibility although I still can't understand how I could drive the car into the garage and turn it off and have this scenario occur? Non the less I took a photo of the front of the dampener. In the photo I can see pin #3 is in it's place but I think the woodruff key must be under the center washer and bolt area? Next on my list is to check the ohms on the CCV tomorrow evening and either way replace it on Tuesday evening when the new CCV arrives. I took the Sabbath Day today and went to Church as that is my best peace of mind and release from worlds troubles and Bimmers that won't start....ha ha Will report back on the Ohm check tomorrow after supper. Will check the ohms on the cam sensor while I'm there. Rick in Ohio Quote:
#82
Hey Steve,
I believe mine is the Alusil block. I think I did confirm it when I bought the car about 8 or so years ago. I also understand that it would deteriorate over time. Have NOT checked compressions. I have no reason to believe they are weak but it ran fine when parked so I believe it's something else.....but what do I know :^)! I made a post early on where I did remove the filler cap to verify the chains are intact and turning. All is well there. Thanks for the info about how robust they are! Rick in Ohio Quote:
#83
Will keep everyone posted here as WHEN 'we' find the problem I know this will help others down the road. If you beat me to it then I'll give you a nickel.....If I get mine first then you owe me :^)!
Rick in Ohio |
#84
Oh yea.....this thread will NOT DIE until my car is either running or towed to the salvage yard!!
Rick in Ohio |
#85
Here's a pic of the front of the harmonic dampener. You can see the 'pin' at about the 2 o'clock position but I think the woodruff key is behind the center washer and bolt.
![]() This is the pic of the intake that Roberto asked me to post. This was taken through the front of the throttle body. The horizontal 'line' in the pic is the butterfly in the wide open position. It was held open with a screwdriver stuck through the linkage while I took the pic. This pic saved me a TON of work and I'm very grateful for that!! ![]() Rick in Ohio |
#86
A. You're waiting on the CPS (crankshaft position sensor) and not the CCV. I'm making this clarification because I suspect noobs will be referred to this thread many times over the months to do some basic reading and then ask intelligent questions, to see if they really wish to tackle the problem or are just venting for its own sake.
A2. Please advise if your CPS is an OEM unit. If not, get another one, assure them that you'll send this one back once you receive it, however, if you can test it on the car after finding some way to avoid scruffing it around then do so first before sending it on back. B. The first picture - vibration damper - if the woodruff key is behind that, this is going to be way less than straightforward. You'll need a torque wrench amongst other things, and it might be a smart move to have a new woodruff key standing by (if its not expensive) and have that swopped in even if the old one is fine, to maximise all the work that you're doing. This assumes that replacing the key is a relatively straightforward process. Please google for that info (or call BMW back for another free consult, they should oblige since they've been useless so far). C. The second picture shows oil pooling at the rear. You might be able to mop that up with a sufficiently long and firm probe ( the magnetic pickup comes to mind) wrapped in paper towels or cloth. If anything falls apart (take another picture and inspect), use a pair of metal tongs to extract it. Or, if you judge that the ccv plate needs to be changed (more likely the gasket and not the plate itself) then you can wait to clean that up at that point. Or you can remove it first to clean the oil and then reinstall with an appropriate gasket sealant for a temporary fix. For something like this, clear silicone window sealant or a combo of that and rtv gasket sealant should suffice as a temporary fix. Again, this should not be a contributing factor for the no-start situation, as the oil cannot accumulate and worsen during the week long shutdown (oil vapours get channeled up while the engine is running), and your car was running perfectly fine, without even a hint of a driveability issue, before your vacation. D. My strong suggestion would be to get someone to crank the car at full speed without the fp fuse in, and you eyeball and simultaneously video the vibration damper to see if there's anything weird going on. Hold it and yank it around from several different angles. Basically, see if you can find any fault with it. This should be done with the current cps reinstalled. E. Please keep a zen state and an open mind as you approach this situation, to permit ideas to occur to you, both new ideas on what to do, and ideas on how to do something already planned in an even better manner. The zen state also enables you to make other observations about your car that may not be related to this issue but are worth knowing eg now you know you need to fix the ccv system, perhaps you'll notice some piping that is nearly busted, belts which need to be changed, whatever. All of these are important noticements and can help you solve problems or optimise your car during this long interval. You'll feel far more productive about the downtime when it is all over. F. You might want to consider bringing forward some other downtime work that you had planned for the near future, such as changing the WP, thermostat, fan clutch, radiator, etc....basically to maximise the downtime that you have now. A great way to turn a repair into a servicing, or an upgrade. G. All of this assumes that you're going to get your car up and running. If you are not on board with that completely, its going to be very difficult to get out of this particular slipstream, considering its apparent complications. You will not have the correct mindset to lose battles along the way and yet ultimately win the war. Good luck. rgds, Roberto Last edited by robertobaggio20; 01-07-2013 at 12:47 AM. |
#87
Took another look at that picture. Looks like alot of oil sir. One sharp left turn to impress the ladies and there's a good chance the right bank will get a sudden flood. I think you ought to take of the rear ccv plate and drain that out properly. Reuse the same plate with a new gasket or substitute with good gasket sealant - you're clearly experienced enough to innovate appropriately.
#88
Good woodruff key article
http://www.mazda-madness.co.uk/2010/...-woodruff-key/
I think Steve has likely found the culprit in your car, Rick. There is scanty information on DIYs but I've not looked too deeply. Here are two : http://forums.bimmerforums.com/forum....php?t=1511281 http://www.m5board.com/vbulletin/e34...gd55450-4.html They are certainly within the scope of your personal expertise as far as I can judge it, but the 2 woodruff keys (wkeys ) would constitute semi-major work on the engine. I have hope that it isn't. This stuff does not go bust. It seems to only go bust due to impact damage and poor manufacture....and our cars have no history of this. And it appears that when it does, it does so progressively and the engine will feel different along the way. Rick, did you notice anything different in your engine's behaviour in the past 12 months? Its probably the crankshaft position sensor. We've merely found a new and unique way that the cps causes problems. Rick, please send your cps to the E34 hall of infamy. ![]() rgds, Roberto |
#89
You haven't found anything yet
![]() I think it is highly unlikely the key in the balancer has failed. That is extremely rare. You need to get back to why it doesn't fire when the fuel squirts. The possibility of a bad CPS sounds promising, hopefully that fixes it.
Winter Rules
#90
I agree. I was just throwing that out there as a last ditch possibility.
#91
OP can you post a video clip of how your going about your diagnosis and particularly when you are cranking or turning it over ...
![]() Sent from my Desire HD using Bimmer App |
#92
My video quality would be very poor.....but....take ALL of your spark wires off.....then crank your engine. This is exactly what mine sounds like!
Rick in Ohio |
#93
OK.....2 things.
1-When I looked at the intake manifold photo on my iPhone it looked clean as a whistle. When I posted it here and went back and looked I DO see the reflection in the back of the sump and that must be oil. I'll clean that out as suggested but won't it just come back again? This is from a borderline Crankcase Ventilation Valve correct? Maybe I should replace that bad boy after all?? 2-I brought home my good Fluke multi-meter today and I just checked the OHM's on the Crank Position Sensor.....drum roll please..........It's supposted to read 1280 +or-10% and it reads a whoppin' 498. For kicks I brought it in the house and put it under hot water and it slowly walked up but only peaked out at 570 OHM's. This tells me that Roberto's trick of pouring the hot water on a bad CPS might work if it was only a little out of whack. THE BIG QUESTION - Is it possible that the crank sensor is throwing off the timing of the spark? So....we FINALLY found something wrong with the car. My new Crank Sensor will be here tomorrow and I'll verify the OHM's on it then will install it in the car and cross my fingers when I crank it over. I also checked the OHM's on the cam sensor and it is at 1210 so it should be OK. I thought about putting it where the CPS is but thought I could wait one more day for the new one. I'll check back tomorrow and maybe be able to put this klunker to rest. If not it will rest permenant at SIX FEET UNDER.....ha ha. Rick in Ohio Last edited by rv6rick; 01-07-2013 at 06:06 PM. |
#94
https://wiki.bentleypublishers.com/d...specifications Note that at the top is specifies for the 6 and 8 cylinder engines. Sorry to bust your bubble. Sitll, I would check the resistance on the new one as well.
#95
UH OH....that's not good.
My manual reads: M20/M30 engines: 540 ohms M50/M60 engines: 1280 ohms I'm guessing this could be a bad sign....WHY would mine be bad and be almost exactly HALF of a good one? I'm putting the new one in either way. I won't ask what do I do now....will just wait till tomorrow and report back. Rick in Ohio Quote:
#96
#97
OK thanks. Just did a little googling and I'm finding the same thing....that it should 540 +or-10% so that would mean mine is 'OK. That really stinks!
So if that is the case where should I look next? Rick in Ohio Quote:
#98
![]() When the solution is found, it will probably make us all slap our forehead and go
#99
If cranking the car and it sounds like the plugs are out of it then there is no compression , I would look and see if the rocker arms are moving when you crank the engine and if it doesnt then you have a busted chain , note look at both banks . My 2 cents
#100
It doesn't sound like there are no plugs. It cranks the same as if the plugs were disconnected.....meaning the plug wires were removed.
I checked the chains through the oil filler neck and they were OK. Thanks for your help....I appreciate it very much. I still have a bit of hope that the CPS will be the fix but it has deminised since the possibility of a misprint in the manual. If it's not running tomorrow night then I'm giving it way. Too bad cause I just stuck 4 new tires on it. I'm guessing the car is only worth $1500 bucks at best anyway. What a shame as I have the sales slip for it and it was almost $49,000 new before tax. Rick in Ohio Quote:
