Old 01-06-2013, 04:34 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Originally Posted by cmpcpro View Post
So if I pressure test this system will that show if pipe is bad? Thx
Not necessary if the leak is internal.
No pressure loss
Old 01-06-2013, 05:02 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
No pressure loss
See thats where I am having a hard time understanding this.. if that's the case how are we having air introduced if it's still a sealed system? And if pipe is leaking into valley pan but valley pan is holding wouldn't it just fill valley pan and then continue to flow in it's normal path?
Old 01-06-2013, 05:30 PM
Mein Auto: BMW 745i
Cmpro, try this:
If system works incorrectly, how would it bleed itself???
In other words you cannot bleed it if it leaks into valley pan.
Also read about cavitation
Old 01-06-2013, 08:00 PM
Mein Auto: Nothing
Cmpro, try this:
But thats what I don't understand, the system is obviously bleeding.. I got a bunch of air out the first morning opening the cap, and I got a little air out this morning.. I believe you may very well be right about the pipe, but I really wish I could figure this out so we know for sure.. The only thing worse then being $1k in with same problem would be $2k.. and that one guy who posted same problems replaced his pipe and day and a half later same exact issues.. and Sristopher has just done the AGA pipe along with all new cooling system like me and is running at 108.. I don't understand what more to be looking for, but it seems like there obviously must be something we are over looking.. whether it be the head gaskets, or the cooling pipe, or even the heater core or a fan issue.. something is happening, but there are two people with new cooling pipes having same issue.. also, the vent pipe that goes over the radiator.. I have a super good stream now with new radiator. It was weak when I started, new hoses, etc. made it better, and new radiator made it even stronger.. it's very strong.. even with heater on now it's a stream.
Old 01-06-2013, 08:29 PM
Mein Auto: BMW 745i
Super good, huh?
Watch this video about bmws, it's gonna blow your mind
http://youtu.be/HEmgwn8vgr8
Not much left:
High pressure failure order:
1st in line is coolant pipe seal
2nd is rear plate
3rd heater core
Old 01-06-2013, 09:28 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Dude, I found the problem.....it's a BMW!!!!!!!!!! Lol. Frustrated to say the least. I think I am going to trade it in.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 01-06-2013, 09:29 PM
Mein Auto: Nothing
UPDATE:
Okay guys, I have this lower hose thing figured out.. I have been driving around with INPA on my lap.. Cruising around under light load, the hose is 30c or so.. if I start going up a hill, just giving it light gas, it will climb right up into 50s/60s.. I went up a steep hill at less than half throttle and the DME opened the tstat and brought car down to 96 and lower hose climbed to 84c.. driving down the hill hose dropped to 30c car stayed around 102.. driving in the neighborhoods on downhills it would stay at 30's.. if I start going up hill or give it some gas the lower hose will go right back up to 50's 60's.. then I noticed something.. I turned around on a hill and put it in park.. it climbed to 107 and the car idle would stumble every couple seconds, though I gave it some gas and it cleared up, but I noticed the lower hose would climb as the tstat was opening.. and because of that I realized that the tstat was opening, but still losing the battle.. the lower hose temp was climbing and temp was still at 105, 106, fan kicked on but was very low.. and whenever fan kicks on temps never lower.. Maybe someone else can use this data and come up with something, or explain the reasoning.. but I am wondering if light driving the car just runs on the small circuit and only uses the tstat when under load, or high heat..
Old 01-06-2013, 09:31 PM
Mein Auto: Nothing
Lol, I was thinking the same thing, but I would have to sell mine as I don't want anymore car payments and I've bought way too many new cars for a lifetime.. lost on all.. If I sell what will I buy? I love this car.. I am wondering if our fan is the issue.. also, the guy who just wrote that reply on the I think I found the BMW secret post about changing his cps from exhaust to intake and gaining a whole bunch of power (And he only did one side) could we all have this issue and timing is totally off and causing heat?
Old 01-06-2013, 09:47 PM
Mein Auto: BMW 745i
Instead of complaining, better fix it and keep the car for a few years.
The worst case you pay 300-400$ to replace that rear plate. The good thing is that it's not head gaskets.
Once All leaks fixed it'll get back to normal, but cooler tstat is a must not get this disaster again!
It doesn't make sense to take a loss after you spent so much already.
Old 01-06-2013, 10:38 PM
wjjklj's Avatar
wjjklj wjjklj is online now
Mein Auto: 2013 BMW 750Li X-Drive
I contacted Wahler Thermostat Headquarters to see if they have any ideas for a retrofit lower temp thermostat. I'll let you know what I hear.
Old 01-06-2013, 10:45 PM
Jbrown57 Jbrown57 is offline
Mein Auto: 2004 745i
You guys have me curious.
Checked my 2004 tonite on the way home.
7C ambient, idle at light 99-100C 500 rpm
1750rpm driving 91-96C for half an hour drive.
Will try to check coolant discharge temp. Tomorrow .
Very interesting and enlightening thread.
Old 01-06-2013, 10:58 PM
Mein Auto: Nothing
Hey SF: I really think my fan is dying.. the idle fluctuation I am seeing is something trying to be turned on, it's not a misfire but something kicking in, and off and on, and off.. etc.. I think my fan is shot.. if I disconnect the connector from the lower hose my fan will go on high right? How hard should it blow on high? Should it sound pretty loud? Or just turn normal..? Thanks!
Old 01-06-2013, 11:03 PM
Mein Auto: BMW 745i
Ok, you replaced everything you think, now replace 500$ aux fan.
I mean I'm sorry but your lower hose temp is not related to the fan at all, and you still ask these questions???
Should spin on high, not that loud though. Nothing wrong with fan, fan won't do a thing if lower hose is cold, don't you think it's obvious???
You want real changes?? Remove tstat for now, at least it's not gonna hurt the engine
Old 01-06-2013, 11:18 PM
Mein Auto: Nothing
My lower hose is 69c 70c, etc.. and I still don't hear the fan kicking on.. it seems to start to kick in and then just goes back off, doesn't actually spin up.. When the temp went up to 107 and lower hose was still climbing in the 70's I would have figured the fan would have kicked in on high, yet I hear nothing.. sounds like something is clicking on, then off, then on, then off.. I may be wrong, but I don't have enough evidence to spend another $800 and rip open my engine. I need to figure this out, blindly replacing parts worked when it also took care of routine maintenance but for all I know the PO replaced my pipe.. when I look down the valley of the motor it looks brand new and shiny..
Old 01-06-2013, 11:57 PM
Mein Auto: BMW 745i
69-70 is good enough, but earlier you said 30C. Anyhow if pipe was replaced PO told you?? Then it's rear plate, try to lift a car and look if tranny bell housing has any coolant leaks.
You know fixing a cooling system is always considered the main most important routine maintenance btw, don't you think?? Even oil leak is not important
Ps. If a/c works good then aux fan is perfectly normal. In winter even without any fan your car shouldn't climb to 107C for any reason.
Old 01-07-2013, 12:11 AM
B7M4W5's Avatar
B7M4W5 B7M4W5 is offline
Mein Auto: BMW 745LI
Maybe be its the fan switch has gone bad test the connections on that sencer, just a thought.
E66 745LI 2004 Sport / Sterling Grey Ext. Blck Int./
22" Wheels / ACS Pedals / ACS Rug Plates/
Black Out Tail Lights / Carbon Fiber Blck.-Gry. Emblams/
Grill Chrome-Blck. /
12" Subwoofers 2000 watt Amp
Old 01-07-2013, 03:28 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
I've noticed mine goes to 107 but after 1min 30sec goes down to105 and stays until another start stop..This thermostat is 105c right?Even advanced auto says its a 221f which is 105c.It won't be fully open until then.
Old 01-07-2013, 03:49 AM
Mein Auto: Nothing
I have no idea if PO replaced.. I got no real history.. but valley looks brand new.. lower hose will go to 30c if I am just barely giving it gas, or moving down hill, if I go up hill even slightly on throttle or level and giving it a small amount of gas, but accelerating slightly it will climb up in temp very quickly. Temp doesn't drop so I know DME isn't opening tstat, but hose climbs rapidly..
Old 01-07-2013, 04:14 AM
dolfan13's Avatar
Mein Auto: 545i
Earlier SFbay you said try running without a tstat?How much different would that be than drilling a hole?
Old 01-07-2013, 06:56 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Difference is tstat wont open bc theres a hole in it pissing by and if you have this problem it wont fix it.
Removing tstat engine will remain cool n worse case scenario will be you burn your fan out if it reaches hot enough to kick the fan on idk how durable the fans are to be on almost always at idle...
Either way it wont fix your problem. Fix the leak and get a lower temp tstat is the solution. Even a lower temperature means the coolant doesn't expand as much and the pressure in the system will be reduced by going down 10 or 20 degrees for 95 and 85 degrees respectively. That is the whole theme of this thread so far
I am waiting for our friend sf to feel better so he can finish his testing of these tstats and i can get on this myself... While my system is leak free
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 01-07-2013, 09:42 AM
Mein Auto: BMW 745i
Correct!!!
Even if you remove coolant pipe, but install some plug instead of front seal the system will be leak free, right?
So it explains my theory kinda
and pressure tester will show nothing.
Btw if all leaks fixed and gaskets are new even with oem tstat it's gonna last for some yrs.
Old 01-07-2013, 09:57 AM
745iguy's Avatar
Correct!!!
Some years is the problem. I admit for a car like this that based on production date about 10 years and 6 months old what i have changed in the cooling system isnt that bad which i am assuming that it was all original parts, guessing on the rest it probably was. But if i intend to keep the car til it suffers catastrophic failure that i wouldnt consider repairing id like them few years to be multiplied and im a believer in this theory and the benefits of lowering the temp. Although i guess belief is based on faith and not fact, and fact is more of the case here.
PREVIOUS 2002 745i
Old 01-07-2013, 11:19 AM
Mein Auto: Nothing
Any ideas guys on where I can get a good rebuilt alt? BMA wants $700.. I laughed.. I hear people spending $200-something on rebuilds, and one guy got a new one at the dealer for $400-something.. Thanks!
Old 01-07-2013, 11:41 AM
Mein Auto: BMW 745i
Fact is:
Higher temp- higher pressure
Higher pressure- issues with seals and gaskets.
Believe it or not, but it's simply physics.
Old 01-07-2013, 12:01 PM
745iguy's Avatar
Im not disagreeing with you sf im saying i cannot just believe it because its been proven, i am aware of what happens to fluids as they heat and cool down i have a second class firemen's license in the state of MA (boiler operation license)
PREVIOUS 2002 745i
