Old 01-07-2013, 06:29 AM
SuperTerp SuperTerp is online now
Mein Auto: m4now M5M3 550 760 335RIP
Originally Posted by bear-avhistory View Post
That's too bad. Just a suggestion check out some vendors & magazine sites for posted Dynojets of stock engines & take an average. Should be close enough to get some idea of how you did. This one is a Dinan N55 & I believe you have an N54 which will perform better with the same mods. Dyno 2 is a pure stock N54 but its base is a bit lower then the base in the Dinan dyno; this is why its the delta that's the key not just the raw numbers.
Thanks... I figured to take 20% off the Dinan numbers... Which if I'm around 263 and say 285 I'd be fine with 311 and 341@ crank for a first time in the pool
