Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 01-04-2013, 09:49 PM
Titansilber98M3 Titansilber98M3 is offline
Mein Auto: E36 M3
Rattling Noise From Transmission!!
Help! I recently replaced the clutch, flywheel, pressure plate, throw-out bearing, pilot bearing and shifter with an F1 stage 1 clutch and ltw flywheel kit on my 98 m3 coupe and now I have a rattling noise coming from the transmission when the clutch pedal is not depressed, happens at idle and throughout all gears noise is kind of whiny at high rpm but not prevalent when pedal is being pushed. I thought it could be harshness from not having a dualmass flywheel but since it goes away when the clutch is disengaged it must be something else right?? Any help would be greatly appreciated!! Thank you!!
Old 01-07-2013, 08:56 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Probably the flywheel.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 01-11-2013, 09:37 PM
Mein Auto: E36 M3
I agree I've had no drivability problems I just had no idea how noisy and grumbly it would sound, thanks!
