Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 01-04-2013, 04:20 PM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
Dreaded coolant leak!!
I took the 6 in to see about a leak and this is what the Indy said needed to be done:
engine mounts (leaked all fluid)
valve cover (leaking oil)
transmission pan
coolant pipe (leaking coolant all the way to the tailpipe)
front control arms (car shakes)
gas cap
I was quoted between 3k to 4k.
How was your day!!!
Old 01-04-2013, 05:37 PM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
That is a whole lot of bad, I feel for you. It should be titled "dreaded everything", not just coolant!
Old 01-04-2013, 08:08 PM
FredoinSF FredoinSF is offline
Mein Auto: 650i 330cic and 2 MINI's
If I take my car in for a coolant leak and they find a laundry list of stuff including the gas cap I would start questioning things. If you asked for a full inspection or mentioned other issues that's another story, but the gas cap - really?? How did they find it defective in the process of looking for the source of a coolant leak??
None of these are rare failure points as the miles accumulate, but it's a big list if all you took it in for was a coolant leak fix. You must be frustrated if all these issues were unexpected.
07 650i and 02 330cic
Old 01-04-2013, 10:20 PM
I wanted to get a second opinion before any work was done. I now have a knocking noise coming from the front end when the car is moving. I am taking it to a different Indy tommorrow. I have been pleased with the work he's done to this point.
Oh, and he charged me $105 to diagnose and $30 for the damn gas cap!!
Not real happy right now!!
Old 01-04-2013, 11:35 PM
dubzz24 dubzz24 is offline
Mein Auto: s54 M Coupe, e63 650i 6mt
What do you mean "leaking coolant all the way to the tailpipe"? There shouldn't be any coolant any further back than the heater core (under your dash). Whoever you took the car to sounds a little scheming. Good call on getting another opinion.
Old 01-05-2013, 04:02 AM
645/333's Avatar
645/333 645/333 is online now
Michael
Mein Auto: Black Sapphire BMW Z4 3L
Hi! The dreaded coolant leak is actually the pipe that runs inside the engine front to back, above the cylinder block, where the rubber seals fail and it weeps out of the front of the engine, there is a tiny hole it comes out of!
Any other coolant leak is pretty standard, as it is the above leak that costs the major $'s. BMW split the engine whilst others are using the engineered kit from various suppliers.
The only good news in a sense is that to repair this you will naturally change all of the seals/gaskets etc to get to the part!!!!!!
Does my bum look good in this !
Old 01-05-2013, 07:45 AM
A bad gas cap seal will throw a code on most cars now, at least I know it does on the Euro cars. It is not an unusual failure item!
Old 01-05-2013, 09:37 AM
I know the gas caps can start deteriorating and throw a code. My point was that if the OP took it in for a cooling issue and nothing else, I can kind of understand the shop pointing all the underhood stuff as they poke around, but going as far as the gas cap seems like padding the bill - unless there was a code. This list really depends on what the OP asked for.
Reminds me of my partners MINI that went in for a O2 sensor covered under warranty and came back with 5k laundry list and basically told him the car was one key turn away from self destruction. Some of it was legit such as bushings and all which I had taken care of by my independent but the rest was a tactic to make service dept numbers go up and \ or send him off with a brand new car. 18 months later it still runs like a champ.
Old 01-05-2013, 11:48 AM
Exactly, so why would coolant be anywhere near the tailpipe?! OP where do you see the coolant?
Old 01-05-2013, 05:35 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Sorry to hear about the big laundry list but those are all common wear items.
The shop probably did a scan and found the gas cap error. I've changed at least 3 gas caps over the years on German cars, countless control arms and valve cover gaskets on 2.
A bad coolant leak could down the transmission onto the exhaust pipes then easily run down the pipes to exhaust canisters, especially if you park the car on an incline (like in your sig).
The noise from the front and shaking is a pretty good indication that the front control arms are shot.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-07-2013, 11:31 AM
amanra's Avatar
amanra amanra is offline
Mein Auto: 2005 BMW 645Ci
Crap!!
Sorry to hear about this, I've experienced all of these issues at separate times. I was lucky to have my aftermarket warranty cover these repairs for me, but there was a point where every 2 months I was experiencing something new, and that can be frustrating. In this case, you can get this entire list completed in 1 shot which is much better than what I had to go through.
Old 01-07-2013, 01:08 PM
645/333's Avatar
Michael
Hi Yorgi! showing my ignorance hear! the gas cap, is that the same as the petrol tank cap?? And if so what goes wrong with them that causes a code to be raised! Have never experienced this so would be interested as to its effect?? Many thanks Michael
Old 01-07-2013, 01:10 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2007 BMW 650 vert
Originally Posted by amanra View Post
Crap!!
+1 - sorry to hear about the long list of repairs.
Regards, Greg
'07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs
'11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Old 01-07-2013, 05:48 PM
She's at the shop right now gettin' all fixed up for me so I can ride her another 100k!! Coolant leak is under the intake manifold. He said it needs a cap replaced. Oil leal is a valve cover and main gasket. I told them to change the belts and flush all the fluids. The front control arms were fine.
$2800
Can anyone suggest any other parts that I should replace while there at it for preventative measures??
Old 01-07-2013, 07:34 PM
Yorgi's Avatar
Yes, the petrol cap that you need to remove every time you fill up the car.
There is a rubber seal on this cap that dries out over time and compresses after hundreds of removals, resulting in a less-than-air-tight seal. All modern (OBDII) emission systems pressurize the fuel/petrol tank. Any loss in pressure triggers a check engine light - the assumption being if pressure is leaking from the tank so are fuel vapours into the environment.
Germans are notorious for using low silicon content plastics and rubbers because they are very environmentally conscious. They want the plastics used in cars to eventually break down once the car is retired. The problem is that the plastics start breaking down too soon, within 8 to 10 years, and you start getting all sorts of electrical connection issues and plastic hoses/tanks failing.
The Asians are not afraid to use high silicon plastics and this is one of the reasons they have greater reliability over the Germans.
'04 M3 - track
Old 01-07-2013, 07:44 PM
Yorgi's Avatar
$2800
If you have the "dreaded coolant leak" which weeps out the hole in passenger side manifold cover, then that fix requires at least $2-$3K on it's own. There is also a common coolant leak at the coolant temp sensor that costs about $100 to fix. I would find out what exactly your shop is doing.
The "dreaded" leak requires pulling apart the entire manifold and installing a new pipe from All German Auto. You should at least change the manifold cover gaskets in this case. Check out this DIY thread to see what's involved (download the .pdf), it is a MAJOR job - the dealer pulls the engine and charges $9-$11K for this job.
'04 M3 - track
Old 01-08-2013, 11:27 AM
645/333's Avatar
Michael
Hi! Many thanks for the information, knowledge increased! If you did have a lower pressure in the tank due to the cap being faulty, how would that manifest in terms of driving the car? I appreciate a code is generated and the smell of fuel may also be an indicator, I have seen many cars with fuel stains running down from the fuel tank filler cap, indicating a less than tight seal, but would the cars ie 6 series run properly???? Would you get fuel starvation as it is not being pumped effectively?????
Old 01-08-2013, 10:13 PM
Yorgi's Avatar
Pressure is strictly for emissions. The fuel pump will work even if the cap is removed.
The cap would have to be pretty bad combined with some real hooligan driving to have fuel/petrol leak out of a closed cap. I think what you are seeing is people over-filling at the pump or pulling the nozzle out too quickly (get your mind out of the gutter ) after they stop pumping which causes a spill down the side of the car.
'04 M3 - track
Old 01-09-2013, 12:55 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
Is an engine pull actually required???
Old 01-09-2013, 05:57 AM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i & 2002 745i
Go to the e65 forum and search "weep hole". They are plagued with this issue!
2008 BMW 650i Convertible- LCI.
- ACS style rear spoiler
-Eisenmann Race Exhaust, resonators removed, Magnaflow X pipe.
- LED Angel eyes, plate light and interior package
- Tinted Windows- Charcoal 20%
- Stock 19" summer wheels & 18" M6 Winter wheels
Old 01-09-2013, 06:08 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
No engine pull if using the AGA pipe
http://www.bimmerzone.com/BMW_Perfor...-PIPE-N62.html
you can check out pics and videos
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 01-09-2013, 02:30 PM
Even my dealer does the aftermarket pipe...reluctantly. It is frowned on by bmw but they say thay have to offer to keep from losing to the independents.
Sent from my SCH-I510 using Bimmer App
Old 01-09-2013, 06:44 PM
Yorgi's Avatar
If you don't install the aftermarket expanding All German Auto (AGA) pipe then you need to insert the OEM replacement pipe though the front of the engine. This requires lifting the engine out to slip the pipe in.
Dealer method is replacing a leaky $4 gasket with $9,000 of labour because BMW engineers did not select the best quality rubber for the o-ring on that pipe.
'04 M3 - track
Old 01-09-2013, 07:36 PM
Woo Hoo FREE Donuts
Seems like they could just remove the radiator vs lifting the engine out. I guess less labor charges if they did it that way...
Old 01-11-2013, 04:14 PM
I just got the 6 back from the shop today and here is what was done.
R+R intake and replaced valley plate (Cap) with seal. $1488
Replaced leaking valve cover and upper timing cover seals. $1304
Replaced micro filters.
Brake fluid flush.
Coolant system flush
The car runs much better!!
$3,208
