E90/E91/E92/E93 (2006 - 2013)
Old 01-06-2013, 11:51 PM
Skaggs1204 Skaggs1204 is offline
Mein Auto: 2008 335i M-Sport Coupe
Question E92 335i Brakes/Rotors
It's about time for a new set of brakes and rotors, I would like to have slotted and drilled calipers and a good set of brakes to really bring the car alive. I don't want to sacrifice any performace what so ever but I want something thats going to last and look good.
I have a 335i M-Sport, I'm just saying that because I don't know if that makes a diffrence in the type of rotor and brake comound that are put on stock, but I know they are stock.
Old 01-07-2013, 01:28 AM
Robin128 Robin128 is offline
Send a message via ICQ to Robin128
Mein Auto: 335i auto, Volvo T5 man
How many miles have the rotors done?
One should treat others as one would like others to treat oneself.
Old 01-07-2013, 06:00 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Without better tires and suspension, the brake parts that you want will not increase porformance. You will actually loose braking surface. Drilled stock rotors are for looks. Stick with sloted or stock rotors with a better pad.
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms|
2009 X5 3.0 - AW- Black Dakota/Bamboo | Premium |Tech | Cold Weather | Ipod | Rear Climate |
07 X3 - Sold
07 335 coupe - sold
Old 01-07-2013, 09:19 AM
I've got 57k miles on my rotors and I don't know about the brakes.
I plan on buying some new tires, I hate the run flats, and I just wanted a really good look but I feel that the performace is more important too me.
Okay a second question then...I was woundering if get a brake caliper cover would be a good idea, and if so what would be a good one to get?
Old 01-07-2013, 10:31 AM
thekurgan's Avatar
thekurgan thekurgan is online now
Bad Lieutenant
Mein Auto: S65B40 Powered
I wouldn't cover the caliper, let it cool naturally as it was designed. Agree with not going slotted/drilled with the stock diameter brakes, you'll lose sweep area and true "drilled" rotors should not in fact be "drilled", which weakens them. I'd go with stock rotors, looks like they lasted you quite some time.
08 E90M3 6MT Alpinweiss/Schwartz
Old 01-07-2013, 12:34 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Cosmetically or regarding performance?
Stock brakes are excellent for anything short of track work. Do you need more?
335i, brakes, caliper covers, e92, rotors
