Old 04-07-2011, 07:29 PM
KB24 KB24 is offline
Mein Auto: 2005 645
Originally Posted by bigdgpa View Post
I'm running 255 and have never had a problem!
Im considering doing the 255 over the 245. But im running 235/30/22 right now, and the metal thing under the shock is close to the top of the tire. Right now my overall diameter of the tire im running is 27.6, the 255 will be 27.9. Im not sure if ill be ok without rubbing. The offset of the rims also plays a role in this issue. Ill just have to figure this out on my own
Old 04-07-2011, 10:19 PM
Yorgi's Avatar
Yorgi Yorgi is offline
If you guys are rubbing on the bottom spring perch then you probably need a spacer. The important measurement between the different tire sizes is the radius. A 1" increase in radius = 1" closer to the spring perch.
Stock 245/40R19 = 13.35"
235/30R22 = 13.77" (+3.05%)
245/30R22 = 13.89" (+3.86%)
255/30R22 = 14.01" (+4.68%)
295/25R22 = 13.90" (+3.93%)
I went out to measure and found my OEM 19" stock ellipsoids have about 1" clearance between the top of the tire and the bottom of the perch. Increase in radius for stock vs 255/30R22 is 0.66" so in theory there should be plenty of room.
The spring perch is slanted though, so the closer to the strut you go the less clearance there is. If you are rubbing due to high offset wheels a spacer will give you more clearance to the strut and the bottom of the spring perch.
On a side note, I included the diameter % increase in brackets. Even if the 255/30R22 fit they are 4.68% larger than stock which is far beyond the recommended 3% max increase in diameter.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-12-2011, 08:17 PM
supe74 supe74 is offline
Mein Auto: 645CI
I have deep well 21" strut rims and it rubbed a hole in my windshield washer resevior. Depth mtters
Old 04-18-2011, 03:04 PM
Jitoo Jitoo is offline
Mein Auto: 2006 BMW 650i Convertible
Hi Guys,
So I decided on the 22's and could not be any happier, attached are some quick pics and let me know what u you all think.
I also had my lights tinted and the grill has been customized - black with just the front in chrome.
Let me know.....
ID:	275134   Click image for larger version
ID:	275135   Click image for larger version
ID:	275136   Click image for larger version
Old 04-18-2011, 03:13 PM
Yorgi's Avatar
The car is looking great. Love the concave on those rear wheel spokes. Tinted lights and grill are a nice custom touch.
'04 M3 - track
Old 04-18-2011, 05:48 PM
jimgraves jimgraves is offline
Mein Auto: 2005 645Ci & 535i
That is an unusual and interesting wheel design. Your car likely sits about 1/2 inch higher than before so you may want to consider a slight drop.
Old 11-14-2012, 05:43 PM
Realism Realism is offline
Mein Auto: BMW 650i
Jitoo....did you get your tint done at a regular window tinting place or somewhere different?
Old 11-14-2012, 05:50 PM
Regmatc's Avatar
Regmatc Regmatc is offline
Mein Auto: 05' 645
Just got some new 22"s. Just sharing...
Sent from my SPH-L710 using Bimmer App
Regmatc
Old 11-14-2012, 05:52 PM
Regmatc's Avatar
Mein Auto: 05' 645
Regmatc
Old 11-15-2012, 02:41 PM
It is a spay on and not a window tint. Nit sure what the guy used because I bought tint spray from the auto shop and it did not look anything like what he did
Old 11-16-2012, 07:37 AM
mgonza1 mgonza1 is offline
Mein Auto: 650 i coupe
They look great ( pics of 22" Giovanni's )
22' wheels look great, had them on my 650 for awhile, but opted for 20' M6 wheels. Personally I think they do not ride well. I have posted a pic. with 22" giovanni's that were on the vehicle.
By the way, for anyone who might be looking for an immaculate 650i I am selling mine. Loaded with all options and only 17,300 miles. I will be selling with the factory run flat tires ( shown in pic. ). The car is very reasonably priced as I am relocating. Anyone interested please pm me. A blessed holiday to all my friends on bimmerfest.
Name:	2007 BMW 650i on 22's 003.jpg
ID:	349725   Click image for larger version
Name:	2007 BMW 650i on 22's 009.jpg
ID:	349726   Click image for larger version
ID:	349727   Click image for larger version
ID:	349728   Click image for larger version
Old 01-08-2013, 12:41 AM
Chico 6series Chico 6series is offline
Mein Auto: 645Ci
I have a 6 series with 22 inch staggered offsets and I was wondering how could stop the rubbing on the back when i hit deep bumps or if someone is in my back seat???
