Old 02-28-2012, 02:35 PM
88Stanger 88Stanger is offline
Mein Auto: USA
2009 335I ticking noise from drivers side engine compartment at idle
I have noticed a ticking sound that is louder than normal coming from the drivers side of engine compartment. This sound is something like what others have described as lifters, but I have read that the N54 engine typ does not have this issue, so I took it to the stealer for service to look at it. Withing a few min. the tech found the problem. On the Drivers side, towards the very back of the engine compartment there is an emissions purge valve that takes the fumes from the gas tank and sends them into the intake. This purge valve's opening and closing is the source of the sound. It is alot louder than the tech has ever heard before and so they are putting a new one in under the warranty.
Just wanted to pass this info on to anyone who may also have this noise. The tech said that it would more than likely be just fine, but due to the loud sound, he will for fear that it may be going bad.
Old 02-28-2012, 02:52 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
Incorrect, it does, just not to the extent of the N52.
Sounds like they nailed your tick.
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 02-29-2012, 07:50 AM
Mein Auto: USA
thekurgan,
Sorry, I stand corrected. I was unsure about it but they did fix the ticking noise on warranty.
I do appreciate the info though.
Old 02-29-2012, 09:54 AM
thekurgan's Avatar
Bad Lieutenant
thekurgan,
It is rare from what I understand. We had it in the N54, only once, and it was cured by driving to work in 4th on the highway, so in my case, it was just some air in the lifter assembly. Others have had different issues. Glad it was taken care of though, from what I understand, dealers are understanding of the issue.
Ilse
Bruna
BMWCCA #453648
Old 01-08-2013, 05:06 AM
WendyS WendyS is offline
Mein Auto: E92 2009 335xi
While searching this forum for info on my odd intermittent ticking noise I found this thread... sounds exactly like what I have. I've only owned my 2009 335xi for 2 months, so I took it to the dealer to make sure it was ok... still under warranty. They said the ticking noise was normal for the n54 engine and it was a combination of the fuel tank vent valve and fuel injectors. I was told the n54 is just louder than most, especially in cold weather. I hope they are right... can't wait til summer to hear if it changes.
Old 01-08-2013, 06:50 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
No tic here
Old 01-08-2013, 07:52 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Originally Posted by CALWATERBOY View Post
No tic here
No winter there neither.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 01-08-2013, 08:15 AM
No so!!!!
Why, we had a frost in December. No Winter, indeed.
Snow's available few hrs drive East.
