Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 06-28-2012, 10:30 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
DIY How To Remove L7! Do At Your Own Risk
I am Not Responsible For Any Damages
DO AT YOUR OWN RISK!
HOW TO REMOVE L7
1. Open the trunk
2. Remove carpet over spare tire
3. Remove the spare tire cover (board) If Necessary
4. look at the left panel there is a Gray color clip with 2 screws that screw into the floor (remove those)
5. Remove the black rubber molding around the trunk an gray panel.
6. Remove the black plastic cover that is up against the inner trunk wall near the lock. It has 4 black flat plastic screws.
7. At the top an bottom of the left side panel are 5 or 6 black clips (looks like flat screws) 1 at the top an 5 across the bottom. Remove those
8. Remove whole left side panel
9. Depending on the amp you have (For L7 Only) there are 2 metal slide out clips on the side of the amp. Remove those.
******Link For Those Of You Who Have HIFI******http://tis.spaghetticoder.org/s/view.pl?1/07/62/41
10. Unplug Fiber optic line from L7
11. You are done!
I hope I didn't miss anything I try to do this by memory. Just Trying To Give Back To The Community That Gave To Me. Good Luck!
Old 07-13-2012, 10:51 AM
Rookie2008's Avatar
Old 09-03-2012, 06:07 PM
KingSilverback KingSilverback is online now
The Silverback
Mein Auto: 2006 750Li
Thanks, this helped me a ton today!
Old 01-08-2013, 09:14 AM
Vee007 Vee007 is offline
Mein Auto: 740i
please excuse my stupidity but what is L7
HTML code is Off
