Old 01-08-2013, 04:54 AM
LEOT LEOT is offline
Mein Auto: x-3
2007 X3 rear springs
I see several posts about broken rear springs. Both my rear springs are broken, one just the end piece but another one is broke in 3 places. I don't want to lower the car any more using the Eibach springs like some have done. I would like a beefier spring so it doesnt happen again. The dealer wants $170 per spring. Found a company on ebay selling a new set for $169 which is 1/2 the price with free shipping, Made by Lesjofors??
Any suggestions where to buy or is there a better, stronger replacement spring. I carry quite a bit of weight in my trunk at all times and have had problems with rear tire wear...assume now it was caused by the broken springs
Old 01-08-2013, 06:57 AM
mlukas161's Avatar
mlukas161 mlukas161 is online now
Mein Auto: 03 330i, 04 X3
Genuine BMW replacement springs for 148 at Tischer BMW.
This is where I buy all of my replacement parts if I want to stay with original.
http://www.trademotion.com/parts/200...iagram=1935620
Old 01-08-2013, 09:29 AM
todd92 todd92 is offline
Mein Auto: 07 X3, 05 ZHP
I would go with the eBay over the OEM, which you know will eventually break again anyway.
Old 01-08-2013, 11:32 AM
jdauria jdauria is offline
Mein Auto: 323Ci & X3 3.0i M-Sport
I would stay away from eBay.
I am wondering what the part number is and if they are interchangable with any other models.
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 01-08-2013, 11:49 AM
mlukas161's Avatar
http://www.realoem.com/bmw/select.do
Real OEM to look up part numbers to compare.
Old 01-08-2013, 11:50 AM
i did this but the part number never comes up, it says ask your dealership
My Progress Thread
Old 01-08-2013, 12:15 PM
Mein Auto: x-3
I believe the part number is 42-084-50
Old 01-08-2013, 12:18 PM
Can't be, need more numbers. Dont you need 11 digits?
My Progress Thread
Old 01-08-2013, 12:32 PM
Mein Auto: 2004 X3 2.5i
I agree - this is one of those cases where BMW appears to have had a supplier with what seems like questionable product quality over a number of years.
Might be the rear suspension design itself, but not a convincing case for insisting on exactly the same spring to replace a broken one.
I would be more comfortable with an alternate one as long as the maker has a good track record.
http://www.lesjoforsab.com/news/news...=211&sprakid=2
Don't know if the O.E. ones were Stumpp or not, but if they were it looks like they came out of a Slovakian plant.
The Lesjofors ones could be from several countries, including China as always seems to be the case now.
But worth a gamble I would say.
Old 01-08-2013, 12:37 PM
^or don't gamble and get the OEM one, do it right the first time will save you money later one. Maybe Tischer (link mlukas provided) will have a warranty on them??
My Progress Thread
Old 01-08-2013, 12:57 PM
So 'doing it right' is using an OEM part which is known to fail?
Old 01-08-2013, 01:03 PM
Unless you can find one that is known NOT to fail and has backing I would still go with OEM. Like I said, maybe Tischer will give a warranty with it. Or just upgrade to Eibach springs
My Progress Thread
Old 01-08-2013, 01:38 PM
mlukas161's Avatar
From Tischers website:
"All Genuine BMW parts/accessories we sell carry a 2 year - unlimited mileage warranty valid at ANY BMW dealership within the US. No warranty applies to any part(s) shipped or taken outside the US. The warranty MUST be done on a repair order and diagnosed by a BMW technician through your local BMW dealership's service dept. This means unless you're local, you must go to your local BMW dealership and have the warranty issue resolved. Make sure you hold onto your original sales receipt we enclose with every shipment, or contact us at gethelp@getbmwparts.com with your order # for a replacement invoice - you'll need it to get a BMW parts warranty done at your local BMW dealership."
Although I will say I went with Eibach Pro Kit springs because they were less expensive and I wanted to replace all four at the same time.
And Eibach has a 1 million mile warranty.
Old 01-08-2013, 01:43 PM
gp500 gp500 is offline
Mein Auto: 2007 X3 2.5si
Both rear springs broke on my 2007 model. If I had known that Lesjofors made springs, I would have chosen those instead of OEM. IMO a reputable company with good products.
Old 01-11-2013, 04:55 AM
Mein Auto: x-3
Bought the lesjofors, $169 for pair, half the cost of dealer, free shipping and received in 2 days, they are made in Sweden
Old 01-11-2013, 04:58 AM
Let us know how they hold up
My Progress Thread
Old 01-13-2013, 02:59 AM
Mein Auto: x-3
The ends are thicker than the original so I'm hoping they are stronger
Old 02-03-2013, 01:29 PM
As the broken rear spring problem seems to affect all X3 model years, and other BMW models too, it is good that those possibly stronger Swedish Lesjofors are an option to O.E.
Was wondering if there is a best practice method of replacing them and came across a 3-series video that shows a way to avoid the crowbar method members here have used.
Makes use of the car's scissors jack to create space between the upper and lower mounts so the spring can easily be slid out and replaced.
Not sure if the X3 has the same areas where you could locate the jack base and the cradle, but looks less nerve-wracking than levering a spring out. Any thoughts?
Old 02-03-2013, 03:24 PM
Mein Auto: x-3
I used a 4 ton Puller from Harbor Freight to spread it but the same idea as the video. Was a piece of cake to change. Was able to do it myself in no time
Old 02-03-2013, 03:31 PM
Pleased to hear that it was an easy job.
I read that Z4 owners who have to do theirs can just have a helper stand on the hub to get the necessary separation for spring removal.
That might work for the X3 as well, although a helper over 200 lbs. could be necessary.
Old 02-09-2013, 05:56 AM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
Using the scissor jack is a great idea--I never thought of that! But please use jack stands--I've had a trolly jack like that one fail before.
Old 02-25-2013, 08:13 PM
jerseypaul jerseypaul is offline
Mein Auto: 2006 X3
rear springs
Hey, I just replaced my rear brakes and noticed that both my rear springs are broken. Just a small piece is broken off. How dangerous is this? How long is it safe to drive before replacing?
Old 02-28-2013, 09:14 AM
kirasir kirasir is offline
Mein Auto: BMWs
Depends...mine are broken in exactly the same way and I've probably been driving on them for at least 20k km (didn't even realize anything was broken until I put the winters on and saw the pieces).
I already have the replacements but it's just too damn cold outside to put them in.
Old 02-28-2013, 01:28 PM
Mein Auto: 2006 X3
Which replacements did you go with?
Old 03-04-2013, 02:11 PM
BuckNaked BuckNaked is offline
Registered amUser
Mein Auto: '95 540i 6-speed
I have a 2007 X3. 58,750 miles. The rear springs were replaced around 50k under maintenance agreement, n/c.
I will be keeping an eye on the oem dealer part if they are known weak. The consistant break points concern me.
As far as Eibach and other after market; some offer stock ride height.
Rockauto has a listing for Boge:
front:
BOGE Part # 25P260 Spring Design: Coil Spring
For vehicles without M-technics; Front Axle; eng code [M54 B30]
rear:
BOGE Part # 2597E0 Spring Design: Coil Spring
For vehicles without M-technics; Rear Axle; Heavy Duty Version:; eng code [M54 B30]
