E90/E91/E92/E93 (2006 - 2013)
Old 01-07-2013, 08:01 PM
Bill-SD's Avatar
Bill-SD Bill-SD is offline
Mein Auto: 2007 335i Coupe
New OEM brake pads
I'm shopping for new brakes for my E92 335. I've been thinking about ceramic pads to avoid the brake dust I've been dealing for the last 5 years. I know I've read that the newer cars don't have the same brake dust problems the earlier years had becauce the pads were different. Is that really true, and if I were to buy new OEM pads would those be the ones I get? If OEM doesn't still have the dusting problem, that's what I'd probably go with. Tischer seems to have pretty good prices on brake kits.
http://www.trademotion.com/partlocat...gid=4462&tab=1
I'm also open to suggestions for pads/rotors.
Monaco Blue/Saddle 335i Coupe - Auto|Sport|Premium|Nav|CA|Sirius|Heated Seats|PDC
Old 01-08-2013, 06:49 AM
jburke4689 jburke4689 is offline
I have an 07 335i and just replaced the rear brakes with OEM pads and rotors from Tischer. The dust is the same as it used to be. I also just bought my wife a 2013 X5. Brake dust is the same as it ever was. Are you replacing just the pads or pads, rotor and sensor. Tischer packages them up with caliper grease for a decent price.
Old 01-08-2013, 07:30 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
the part numbers for the new pads should be:
34116794920 (F)
34216790762 (R)
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 01-08-2013, 09:52 AM
bear-avhistory bear-avhistory is offline
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
Very low dust on my 335is factory pads _ lots & lots of dust on my factory 330Ci pads.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 01-08-2013, 10:59 AM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is offline
(formerly SD 335is)
Same here. Practically no dust on my wife's 335is, although I'm sure that the Ferric Gray wheels help hide it a bit. On the M Roadster, so much dust that a 4 mile round trip to the grocery store after a wash and the front wheels are gray and need washing again.
- Tom
Old 01-08-2013, 11:11 AM
ECSTuning's Avatar
Mein Auto: e30
On the 335i you'll want to step away from the genuine pads if you want a lower dusting pad, even the newest version of the pad from BMW is a rather dust pad. The best option would be to go to an aftermarket pad, Hawk HPS pads are our most popular for the 335i, they are a performance upgrade pad that's also going to be very low dusting. Since you're looking at a service kit check otu the ones found HERE, the performance kits utilize Hawk HPS pads, our ECS GEOMET rotors, and ship free inside the continental USA.
800.924.5172
OEM BMW Part Number Search
Old 01-08-2013, 11:36 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
I have had excellent luck with Akebono pads and Zimmerman rotors - both on my car and my wife's X3.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 01-08-2013, 12:09 PM
I do about a 1000 miles a month & wash the car about once a month. One pic is recently washed front wheel the other front has about a bit over 3 weeks dust on it. Would have added the 330 wheels but all you would see is black after two weeks
The difference between the wheels condition is a bit closer then it looks because the clean wheel is a flash picture while the dirty one is with no flash.
ID:	356706   Click image for larger version
Kevin
Old 01-08-2013, 12:13 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
StopTech makes some really nice alternatives to the stock pads as well:
http://zeckhausen.com/BMW/E90.htm
StopTech Street Performance brake pads are StopTech's newest formulation, offering an unusual combination of good bite, low noise, and extremely wide temperature range, making them ideal as "dual use" street to medium track pads. These are the standard pads included with StopTech big brakes and are now available for many OEM applications. These are Zeckhausen Racing's preferred high performance street pads.
08 E90M3 6MT Alpinweiss/Schwartz
Old 01-08-2013, 06:48 PM
Bill-SD's Avatar
Thanks for all the info and suggestions. I usually try to stick to OEM parts but I think I'm leaning toward trying aftermarket. Lots of choices, but some sound really good.
Orient - Did you new OEM pads replace the old pads, or are they both still available? I'm guessing that if I decided to go OEM I'd have to specifically ask for the new part numbers?
Old 03-14-2013, 07:07 PM
Bill-SD's Avatar
Just an update:
I decided to go with Akebono pads and Zimmerman rotors. I am very happy with the results. The brakes feel a little different, but not in a bad way. It stops really well, and after a few weeks of driving there is zero dust. I wish I would have done this sooner.
Old 03-14-2013, 07:59 PM
Princeton
Glad you made that choice!
Old 03-20-2013, 07:40 PM
ddtan ddtan is offline
Officially Welcomed to the 'Fest!
Mein Auto: 07 335i Sedan
Originally Posted by Bill-SD View Post
Just an update:
Which Akebono pads did you get, and where did you order them from?
ED 4-18-07: AW335i E90
Redelivered 6-15-07
Old 03-20-2013, 07:46 PM
Princeton
I got them both at Auto Parts Warehouse on the 'net. I got the Euro ceramic pads and the coated rotors.
Old 03-21-2013, 05:20 PM
Bill-SD's Avatar
I got my pads from fcpeuro.com, and the rotors from autohausaz.com.
